Results 1 to 10 of 11
Thread: i need help installing a mobile dvd player
    Sep 2005
    having trouble where to connect the red, yellow and black wires i was told that the yellow and red are suppose to be connected to the fuse panel but where on the fuse panel and is the black wire the ground cus it has a metal ring at the end of it please help me anyone...the car is a 91 camaro
    Elsewhere
    Perhaps cosulting the owner's manual would yield some results?
    If that's too difficult, how about passing along the make/model of the unit? Are the wires from the unit itself or the car's wiring harness?
    Next time ask something that we can answer.
    How about the Wiki?
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    Red is memory and should be plugged to a +12v source(the battery) yellow is power in and should be connected to the ignition (12v) ( or a relay to the ignition ). Black is ground 0v, connect to chassis. Dont forget to fuse the wires ( yellow and red) yellow is higher amperage than red 500ma should be enough for the red wire and 10 amps for the yellow.
    Jun 2005
    chicago, Illinois
    Quote Originally Posted by kevinlekiller
    you have that backwards. Red is memory and should be connected to a switched +12V (Ignition) and yellow should be connected to a constant +12v
    It would really help if we knew what car you had and if you were using a factory adapting wiring harness or if you were cutting away at the factory wires like a newbie.
    PROGRESS:
    Sep 2005
    Quote Originally Posted by pancit175
    the car is a 1991 camaro and yes i am using the factory adapting wiring harness.....i have tried to connect it to the fuse panel like u said red to the ignition plug of the fuse panel witch does have a switch and yellow to the battery plug of the fuse panel...after doing so the dvd player would not turn on but the power button light goes on but wont work....im guessing i need a better ground...please quote if im doing this right thanks again...
    Sep 2005
    Dec 1969
    Its not called memory for nothing. What happens when you take out power from ram? You lose the data , same on the radio , its called memory so when theres power to that wire your stored chans and settings dont erase.
    Edit: Also if you take a look at the fuse of the memory wire its usually 500ma while a yellow wire is 10 amps. That says it all.
    Dec 1969
    Quote Originally Posted by angelmar650
    Connect relays to the wires of your head unit, save your self some trouble
    Jun 2005
    chicago, Illinois
    But You still have it backwards, Yellow is the wire associated to memory, while Red is associated to the switched turn on on most automotive aftermarket products.
    Unless otherwise specified within the installaion instructions
    PROGRESS:
    Dec 1969
    On my 3 head units , the red wire is the one that needs to have power 100% of the time. And the yellow wire is the wire that needs power only when the key is in ACC or ON position.
    I guess some Head units are different.
  1. PS2 as my DVD player?
    By Skipjacks in forum Off Topic
    Last Post: 02-14-2005, 07:41 PM
  2. no DVD picture w/ media player and nvdvd
    By warnockm in forum General Hardware Discussion
    Last Post: 01-04-2005, 09:29 PM
  3. FS: slim DVD player 8/24x
    By swissRv in forum Classified Archive
    Last Post: 11-10-2004, 10:07 AM
  4. Videolan as the DVD player.
    By Skraggy_uk in forum MediaCar
    Last Post: 05-25-2004, 10:48 AM
  5. Saw this today 2 LCDs and Mobile DVD player for $278
    By krazy1ox in forum LCD/Display
    Last Post: 05-12-2004, 03:52 PM
