Results 1 to 2 of 2
Thread: Adding another fuse??
    Apr 2005
    Queens, New York
    Ok well i am redoing the setup of my system. Now stupid me never left ANY extra lenght of the power cable. So I am relacing my amps elsewhere and the power cable is not log enough. Instead of re-running another pwer cable I would rather just put and inline fuse there. But would i have to put the same exact rated fuse that is at the battery, to the inline fuse i am going to add rite before the amps?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Oct 2004
    you could use a smaller fuse if it's adiquate for the amp, it's usually prefered so if you blow a fuse it will be the interior one only...
  1. Fuse popping, wire heating up!
    By gumbi4u in forum Power Supplies
    Last Post: 06-29-2006, 10:01 AM
  2. Wiring, fuse, amp, relay questions
    By Vee24 in forum General Hardware Discussion
    Last Post: 05-25-2005, 07:03 PM
  3. Lilliput Lcd fuse blown help!!!!
    By fernando11554 in forum LCD/Display
    Last Post: 05-16-2005, 11:54 AM
  4. Xenarc fuse and power help required
    By Scouse Monkey in forum LCD/Display
    Last Post: 02-18-2005, 02:45 PM
  5. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 04:59 PM
