Page 5 of 10 FirstFirst 12345678910 LastLast
Results 41 to 50 of 96
Thread: Need help building VW Monsoon amp input
  1. #41
    Maximum Bitrate kbyrd's Avatar
    Nov 2003
    Northern Arizona
    Quote Originally Posted by WebDog
    I bet i have seen the awnser to this before but i cant remember...
    why dont we use the 5V out of the M1-ATX?
    See post #15 of this thread. The 5V out of the M1-ATX isn't steady. It will introduce noice.
    Also how are you mounting your LCD? i got the TMZ but it wont fit with out mods to the dash...
    That's a good question, I got the TMZ bezel and chasis too. I plan to chop a few inches off the back. Then, there's another thread around here on plans for an additional bezel for VWs that just slides over the TMZ bezel to give us a good fit. I haven't done any of this yet as I'm having trouble getting a working LCD in my hands.
    My worklog.
    Status: VM GTI sold, got out of the CarPC tinkering hobby, but I still think about getting back in.
  2. #42
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Well i just finished my cable...
    Figured i would post a pic of it.
    Im gona replace the 1/8" plug with a higer quality one tomorrow.
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
  3. #43
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    This is cool. I want to post a FAQ on this but need to make sure of the exact circuit diagram. Web Dog, could you do one for that picture above? Also part numbers and sources for the connector (if they're in the thread, just say so and I'll re-read it and pull them out).
    Want to:
  4. #44
    Quote Originally Posted by Bugbyte
    yea i guess i could do that, not sure how to make it a corret diagram but i can make it a human readable one..
    I beleve most the part #s are in the posts.
    1990 Jeep Cherokee
  5. #45
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Human readable will be just fine. Even scanned pencil sketch will do. Thanks!
    Want to:
  6. #46
    Nov 2003
    Northern Arizona
    Here's my schematic
    It's really simplified and probably doesn't make much sense without the pictures and information in this thread (for instance, the monsoon adapter had 8 wires coming from it, but I've joined them into three groups).
    Where the arrows join, I've used quick-connects. I've got this built, but it's noisy (no surprise). It sounds like noise coming from the computer. So, I'm building another one that uses rca connections so I can put a ground loop isolator inline. I'll post schematic and pics when that is done.
    My worklog.
  7. #47
    Quote Originally Posted by kbyrd
    I would just put it on a pcb bord, i put everything on the board and have no noise... you could still do a ground loop isolator but then everything else is on the board at least.
    1990 Jeep Cherokee
  8. #48
    Jun 2005
    Albuquerque
    I'm having the same problem. Please please please please tell me if you make any progress. What does the noise sound like exactly? Mine is engine noise AND harddrive noise. It's gotten to a point where I just wanna throw it out my trunk! AAAAH! (not cause the noise is so bad... because I can't figure out how to fix it!)
  9. #49
    Maximum Bitrate BoraXP's Avatar
    Jul 2003
    tips from my experience with VW's and noise
    no inverters
    use quality sheilded cable
    i would recommend trying to mount your little doohickey in a aluminum project box and upgrading all the wires on it
  10. #50
    Nov 2003
    Northern Arizona
    I built my "RCA" version of this (no pics):
    - headphone jack to RCA, with an injector port for 5V tied to the ground, and a capacitor to protect the headphone jack.
    - Monsoon harness to RCA.
    I then put a ground loop isolator beteen the two RCA plugs. I got nothing. In hindsight, I should have seen this. The ground loop isolator completely removed the 5V I had injected. So, I replaced the ground loop isolator with a length of good quality RCA cable. I'm not sure but I think it there may be more noise than before (could be my soldered connections suck this time).
    So, I assumed the noise was coming from the 5V which is fed from a 12V from the PSU. If that's the noise source, then I can't run it through a ground loop isolator, but could I provide a better source for it? I'm thinking of taking 12V and ground from the car (maybe even the same leads that power the amp?) and using that for the 5V. I would control it via a relay so it wasn't on all the time.
    Another possibility is that the noise is coming from the headphone/speaker output of the M10000 soundcard. If this is the case, then running this through a ground loop isolator will help, but I still have to inject the 5V after the isolator.
    Grrrrrrr.
    Finally, from what we know about the orignal monsoon head unit output, I still think I shouold be appplying 5V on all the L/R+ as well as the common ground. Would this have the side effect of eliminating noise generated by the 5V circuit since the + and - lines would fluctuate in sync leaving only actual signal as the difference between them?
    My worklog.
  1. Camaro / firebird Monsoon setup (NOT VW) HELP
    By camarossguy2 in forum Car Audio
    Last Post: 04-14-2009, 12:02 PM
  2. VW Monsoon
    By askthefool in forum Car Audio
    Last Post: 08-03-2006, 09:27 AM
  3. Couple of questions about the monsoon system
    By Bugbyte in forum Car Audio
    Last Post: 07-07-2005, 08:47 PM
  4. amp with digital input?
    By etrik in forum General Hardware Discussion
    Last Post: 05-08-2002, 07:15 AM
  5. Audio and amps - building a preamp.
    By claylong in forum Power Supplies
    Last Post: 03-26-2002, 10:45 AM
