Results 1 to 5 of 5
Thread: Amp problems??
    Aug 2005
    Amp problems??
    Okay everything was going fine then one day I was on brake at work so I turned on my computer to watch a lil bit of a movie (with the car off) and everything was fine a few minutes later I remembered that I had to go do something so I turned the car on and all my sound cut off?? and then it would come back and then off and then on and then off it was almost like it was osculating in and out.....now that's all I get when the car is on....it still works fine when the car is off but not when on??? anyone have any ideas?? oh and the amp light will go to fade to red and then come back to green then back to red...
    Jun 2005
    chicago, Illinois
    check your input voltage off the remote line, If you're getting a constant +12v when the system is on than your amps are toast. If you're not getting a constant +12v, then you're remote line is toast. but you can change where your remote line gets powered
    PROGRESS:
    Aug 2005
    but the amp works fine as long as I don't have the car on So I don't see how it could be toast and the remote line is comming off a molex so it will only turn on if the computer is on Soooo if that line was bad it most likley wouldn't work at all (car on or off).....any other ideas??
    Jun 2005
    chicago, Illinois
    Besides your power wire to the amps those whould be my only ideas. I'd still check your remote line.
    PROGRESS:
    Aug 2005
    anyone have any other ideas I'm still stuck??
  1. del
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. Could my amp be bad or did i miss something?
    By sansoo24 in forum Car Audio
    Last Post: 03-05-2007, 02:45 AM
  3. Wiring, fuse, amp, relay questions
    By Vee24 in forum General Hardware Discussion
    Last Post: 05-25-2005, 08:03 PM
  4. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 07:38 PM
  5. AMP problems....again
    By naevity in forum General Hardware Discussion
    Last Post: 02-17-2004, 10:06 AM
