Results 1 to 7 of 7
Thread: Mac Mini in Scion Tc, No Output from Sub
    Jun 2005
    I have removed the stock HU from my Scion tC and replaced with a Mac Mini and Xenarc 700TSV touchscreen. Everything went well except now I have no output coming from the factory sub...how could this be?
    I have the Mac Mini speaker outputs wired into a Pioneer GM-6100F amp via RCA. The speaker outputs from the amp are wired back to the factory harness. I have outputs coming from all speakers except the factory sub.
    Where am I going wrong? The factory sub is supposed to takes its input off of the rear speakers--but if this is true, then how can I have sound from the rear speakers and no output from the sub? I have tried playing with different volumes and gains on the sub and amp. Also, enabling the LPF on the amp produces some low outputs from the speakers but still no output from the sub.
    Any help is greatly appreciated. Thanks!
    Falls Church, VA
    sounds like a question for the scion TC discussion forum.
    Sep 2005
    post pics too - sounds like a cool setup...
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    Subs taking the input from the rear speakers? Never heard of that...sounds like a crossover type thing. BUT IMO you are either misinformed or someone wired the Scion strangely.
    Where are you outputs from the Mini coming from? PCI card or what?
    And with that question comes, where is the output from the MINI that is labeled SUBWOOFER?
    You say you have it connected from MINI --> Amp thru RCAs
    Is that just a pair? One left one right? Or is it dual pairs Front left/right, Rear left/right?
    Either way you have NO subwoofer output as far as I can see from the MINI or the AMP?
    A 4 channel amp will only power your 4 speakers, YOU CANT RUN SUBWOOFERS FROM YOUR SETUP!!!!
    Where do you expect the subs to get their signal from?
    Sounds like you need to power the subs FROM the AMP, meaning you need a seperate SUB channel on the amp...do you...no.
    Subs need power, and you arent giving it to them.
    Either run the rear channels of your amp to the subs and split the front 2 channels into both front and rear with a y-cable. OR buy a seperate mono amp for the subs.
    (0.0%-) starting over
    iPad 3G 64GB, RF 600.5 amp, JL10W0V2, 8 Infinity Components
    Falls Church, VA
    Quote Originally Posted by sdashiki
    I have a 2 channel amp that is presently running my two front speakers (in stereo) and my sub, bridged, in mono. Give me a bridgable 4 channel amplifier and I'll run 4 speakers plus 2 subs in the same config.
    Where do you expect the subs to get their signal from? Line level from rear speakers
    Sounds like you need to power the subs FROM the AMP, meaning you need a seperate SUB channel on the amp...do you...no.Need to determine where the sub taps in and if it has its own internal amplifier. If it has an amp, make sure its turning on.
    Either run the rear channels of your amp to the subs and split the front 2 channels into both front and rear with a y-cable. OR buy a seperate mono amp for the subs.Or stick with what you have and run a passive tri-way crossover.
    My guess is that the factory sub has a factory amplifier. Somehow you cut the turn on for that amp.
    Newbie da1duce's Avatar
    Feb 2006
    dallas
    u need to find factory turn on wire no sub will run off straight radio
    Low Bitrate Mandos's Avatar
    Sep 2005
    Coralville, IA
    As a tC owner and person who has ripped it apart more times than I care to disclose, they're right.
    There is another wire from the factory harness for the turnon of the sub, it's not spliced into the rears.
    The harness you pulled out of the far right square was the sub output. You'll need to splice into those wires to provide them power/ground/turn on.
    Chris Schempp
    Elemental Designs
    Scion tC in progress
  1. Mac mini in dash questions.
    By dfluxnet in forum MacCar
    Last Post: 10-03-2006, 04:02 AM
  2. Mac mini in my 2006 Honda Ridgeline
    By coolcat in forum Show off your project
    Last Post: 04-23-2006, 02:11 PM
  3. First Mac Mini in a Land Rover
    By dmonckton in forum Show off your project
    Last Post: 08-14-2005, 07:53 PM
  4. Hot Rod Company to start incorporating Mac Minis
    By stacheldraht in forum MacCar
    Last Post: 02-01-2005, 01:25 PM
