Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 44
Thread: Good USB sound card - NOT Audigy NX?
  1. #31
    Feb 2006
    Durham, NC
    I have mine set up like that minus the line in from the XM. It works well b/c the front and rear outputs output the same signal, so you can use rear for the subs and front for your components. Then you can control the volume of your subs via the computer. Some people complain about it's sound quality, but I think it sounds good.
    Check out my review here.
    in progress
  2. #32
    Low Bitrate DaKyy's Avatar
    Apr 2005
    Finland
    I just received the UCA202. Works fine on my desktop as a soundcard. I'll get it installed to my car.
  3. #33
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    Quote Originally Posted by lcaruca97 View Post
    ha, you said Behringer and high-quality in the same sentence.
    aaaaargh damn you..... I was gonna say that
    @Merzbow: really, saying something like "I'm probably the first one using a profi mic in my car", first of all, comes across like you just want to brag, but then mentioning it's a behringer.... well... you just fell through..... I mean come on.... wanna be impressive? buy some real stuff, couse..... aaaaargh
    you do know behringer is one of the largest and CHEAPEST copycats in the world, right?
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
  4. #34
    Apr 2005
    Finland
    Installed and working. Cannot say anything on the sound quality, because I'm not an expert but what I can say is all the noise from either PC or car alternator is gone. Now I can up the volume from my headunit way more than before without hearing any noise.
    Best of all, no drivers needed. Acts as a USB Audio Device. No hibernate issues. Doesn't need much power from USB. I have a 15ft USB cable and a passive 4 port hub. There's a BT dongle, 1GB USB stick and the UCA202 connected to it. Without any problems.
    I don't care if Behringer is considered crap by someone on this forum, It'll serve my needs perfectly for its price.
  5. #35
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    can the input be 'passed through' to the output so you can hook up an xm-direct box to it?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  6. #36
    Apr 2005
    Finland
    I have no idea if that works. If I remember the reviews It doesnt work that way.
    edit: although the manual says it should be possible. So dunno...
  7. #37
    Jun 2006
    Abele, Belgium
    you shouldn't care about what other think or say, or give any attention to my opinion about behringer, cause as long as you're happy it's ok. my post really was specificly directed to that one guy that was bragging about his so called profi mic.
    CLARION HX-D2
  8. #38
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by JasonWW View Post
    SPDIF pwns.
    only if you are using SPDIF into an amp or into a processor....
    I'm trying to get away from it if at all possible.
    Jan Bennett
  9. #39
    _
    Mar 2004
    Little Elm, Texas
    Ultimate USB, Firewire, External Soundcard List
    now stickied.
    would have been useful for the OP in this instance.
    Jan Bennett
  10. #40
    Oct 2005
    Hou. TX
    Quote Originally Posted by RedGTiVR6 View Post
    That's the ONLY 2 ways it can be used.
    Why go away from it? Are you talking about those expensive amps with the USB inputs?
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  1. Hooking up my SB Audigy 2 NX USB
    By Cheekz185 in forum Car Audio
    Last Post: 07-25-2005, 07:02 AM
  2. Trust 5.1 External USB Sound Card 510EX, any good?
    By FociMan in forum General Hardware Discussion
    Last Post: 06-26-2005, 05:16 PM
  3. Sound Blaster Live 24-bit 7.1 Audigy Sound Card
    By djXternal in forum General Hardware Discussion
    Last Post: 04-25-2005, 03:49 PM
  4. USB sound card.
    By ppgt94 in forum General Hardware Discussion
    Last Post: 09-04-2004, 06:43 PM
  5. Anyone find a good USB sound card yet?
    By PoBoy in forum General Hardware Discussion
    Last Post: 07-19-2001, 10:14 AM
