Page 5 of 5 FirstFirst 12345
Results 41 to 44 of 44
Thread: Good USB sound card - NOT Audigy NX?
  1. #41
    Oct 2004
    NY
    my original posts in this thread were when I had the m audio transit, was a good card, but suffered by not returning from hibernation well.... I have since switched to the turtle beach roadie... awsome piece for the money.... every bit as good as the transit, but also recovers fine from hibernation....
    red, I noticed you have the roadie listed as consumer, while the transit is listed as pro.... this isn't correct, the transit should be listed as consumer I think, either way, these are both definatley in the same class & even the same price... having the transit as pro & the roadie as consumer could be a bit missleading....
  2. #42
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by JasonWW View Post
    That's the ONLY 2 ways it can be used.
    Why go away from it? Are you talking about those expensive amps with the USB inputs?
    I'm looking into options to do away with a processor all together, only to process on the carPC.
    and yes, I'm also considering the Dual monitor.
    I found something interesting this past weekend.
    In order to use the dual monitors functionality, you only need one of them in your system.
    As long as you have one of them, you can daisy chain the others and the processing will apply to all channels.
    Jan Bennett
  3. #43
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by turbocad6 View Post
    that's not my thread...
    might want to mention that to the OP, the guy who started the thread....
    Jan Bennett
  4. #44
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I tried to define the difference between "consumer" and "pro" in the thread. Thanks for your input. I am just trying to collect as much info and keep it organized as possible. I have taken your comments into consideration.
    Red-thanks for the sticky
  1. Hooking up my SB Audigy 2 NX USB
    By Cheekz185 in forum Car Audio
    Last Post: 07-25-2005, 08:02 AM
  2. Trust 5.1 External USB Sound Card 510EX, any good?
    By FociMan in forum General Hardware Discussion
    Last Post: 06-26-2005, 06:16 PM
  3. Sound Blaster Live 24-bit 7.1 Audigy Sound Card
    By djXternal in forum General Hardware Discussion
    Last Post: 04-25-2005, 04:49 PM
  4. USB sound card.
    By ppgt94 in forum General Hardware Discussion
    Last Post: 09-04-2004, 07:43 PM
  5. Anyone find a good USB sound card yet?
    By PoBoy in forum General Hardware Discussion
    Last Post: 07-19-2001, 11:14 AM
