Results 1 to 10 of 20
Thread: USB radio tuners?
    Oct 2005
    USB radio tuners?
    i have a hauppage wintv usb 2 TV/radio tuner, and its horrible. DOesn't work with Windows Media CEnter, and they suggest I use their Radio32 application which doesn't work with a touchscreen. The buttons are tiny.
    I want to replace this hauppage stuff.
    What USB alternatives are there for getting radio, especially that work with Media Center Edition?
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    are there any radio tuners that you can connect an external antenna (IE your car antenna) to?
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
    Aug 1999
    Washington D.C.
    That’s the holy grail my friend. Nothing is really good right now in terms of good radio reception and a good antenna interface. Things are in the works just be patient. Good things are on the way.
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by Zip-Lock
    What do you have cooking Nat? Inquiring minds want to know!
    Dec 2004
    I am looking for USB FM tunner too. If you find it please tell me.
    Thankyouu
    Oct 2005
    DISCLAIMER: I haven't checked if this product was discussed before, so my apologies if it was
    I've found something like this a while ago when I was searching for carpc components.
    You can find the product's page here:
    http://www.radio-xtreme.com/
    For people in Europe wanting to buy one you might want to check out
    www.modguru.nl (dutch webshop, is apparently mostly in Dutch though)
    A quick scan over the specs reveals that it comes bundled with Radiator, the remote control that comes with the device is programmable and the tuner is a digital one.
    I don't have any technical knowhow on these things and I haven't ordered one yet, so I can't talk about the quality.
    Once I've ordered, received, installed and tested it, I will give a quick review. (might take a week or two)
    Maybe if anyone with some knowledge of these things can look at the specs and let us know what he thinks about it, I would really appreciate it
    Constant Bitrate TyBong's Avatar
    May 2005
    Rhinelander, Wi
    Ive got some D-link USB radio, the app that comes with it is decent, bigger butons, etc. My old *** dlink has a RCA connector right on it, I havnt put it in my car yet, but past uses it worked pretty decent, I just soldered some decent coax on an RCA end, it worked great.
    MORE COWBELL.
    Newbie TheNewJimJones's Avatar
    Oct 2005
    San Francisco, CA
    Okay, brainstorming time... My car came with this little 2"-3" deep radio reciever and separate tape deck. It has factory harness outputs and a car antenna in connector. I know my electronics and all that jazz but i was wondering if there was someone else out there that has a bit more electronics engineering experience than i do and thinks that they could fabricate other radio recievers similair to this to be compatible with a carputer. I ahve not had the chance to take the radio apart but since it powered the interior speakers when the car was stock i'd imagine it has a built in amplifier. Would there be a way to eliminate this amplifier and run the direct radio output to the carputer and still maintain the external radio controls? I want to eliminate my alpine head unit but still want a good radio. I'd imagine i could just add a connector and pass the radio signal throuh the line in, or maybe even if there was a way to connect it via USB? But id imagine someone would need to develop a driver for that. If you have any thoughts on this please post =)
    Oct 2005
    Miami FL
    I saw this one on a Mac PC its called the radio SHARK from griffin. Its USB no extenal PSU and has an antenna jack. http://www.griffintechnology.com/products/radioshark/
    Im still in the planning station of my CarPC so I have not bought it yet but it looks good.
    Feb 2005
    S Ohio
    so who's gonna integrate the controls for this into frodoplayer
    My NEW carPC
  1. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  2. Radio and Tv usb card
    By CdRsKuLL in forum Road Runner
    Last Post: 04-21-2005, 06:18 PM
  3. D-link Usb Pc Radio Dru-r100
    By mick-uk in forum General Hardware Discussion
    Last Post: 03-20-2005, 05:31 PM
  4. D-link USB radio - echo
    By Rs! in forum MediaCar
    Last Post: 03-10-2005, 03:33 AM
  5. PCI Radio card better than USB??
    By xtreme_db in forum General Hardware Discussion
    Last Post: 09-01-2004, 11:27 PM
