did you use an amplified antenna adapter? also did you hook up the blue or blue/white wire from the harness. If so disconnect those wires because the amplified antenna turn on is through the antenna ( try part # 40-vw53 metra brand, standard antenna adapter is 40-vw10 )
LinkBack URL
About LinkBacks
