I would think it would work like:
CarPC>>XMtuner>>Aux In>>Head Unit
Ok, here goes: I already purchased an Alpine CDA-9830 headunit from Crutchfiedl:
http://www.hookedontronics.com/show_...lpine_CDA-9830
I also purchase an auxillary input adapter to route my sound from the CarPC through:
http://www.crutchfield.com/S-kTOgARk...0&I=500KCM122B
Here is the twist:
I now purchased an Alpine XM Tuner TUA-t020xm off of ebay for a steal (~$36 with shipping)
http://cgi.ebay.com/ws/eBayISAPI.dll...0040%26fvi%3D1
My question is twofold:
a) Does Alpine make a dual aux input adapter? (I couldn't find any)
b) Since the XM tuner has 1 input and 1 output can I wire it like this:
Headunit > XM tuner > Aux In Adapter > RCA Out to CarPC
Thanks in advance for your help
2005 Black Chevy Impala
This unit is discontinued, it is not the XMDirect that most people are using. The cable that comes with it is made to go directly to the headunit.Originally Posted by Maaloxx
You should use this KCA121B AiNet instead M-Bus (KCMxxx)
http://www.crutchfield.com/S-5De00xx...=ainet+adapter
150 buck multiple input KCA410C
Or search AiNet adapter on crutchfield.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
I think this is exactly what I was looking for...thanksOriginally Posted by MatrixPC
The Ai-Net allows for two Aux Inputs, its well worth the 100 you'll spend on it. Can hook use your Ipod also. Thats the setup I have, and great price on your XM radio.
Jeep Grand Cherokee Laredo
Kenwood X790 x/ iP500 Ipod Interface
Elemental Designs 13Kv.2 D2
CDT ES-620 (omg yayay!!!1)
NINe.2X, NINe.2
Your Alpine CDA9830 (I have same one) uses AiNet. The one you purchase is for M-bus HU. The connectors are different between 2 protocols.Originally Posted by Shelbrain
Unless you bought a KCAxxx and thought it was a KCMxxx. They do look the same/similar.
I purchased the right one, just linked the wrong one. I also found this while searching; a little cheaper than $150 Ai-Net device, but if everyone tells me that it is better I will buy it. Check this out:Originally Posted by MatrixPC
http://www.discountcarstereo.com/detail.aspx?ID=321
Bump...any advice before I place an order?
Can you also have digital optical aux in in pxa-h700??Originally Posted by HHdesign
