Results 1 to 7 of 7
Thread: What Soundcard with this setup?
    Apr 2005
    If i'm going to be running 4 speakers (2 front 2 rear) and then 4 subs (8" subs)...what sound card would be able to output enough to run that? And it needs to be a USB sound card...would this sound card be sufficient? i just don't think it has enough outputs.
    http://www.creative.com/products/pro...&product=10702
    or even this one
    http://www.creative.com/products/pro...duct=585&nav=0
    i want to stay away from the NX because i've heard hibernation complaints...but if those two work...which one has better sound quality and higher voltage output?
    Apr 2005
    in terms of amps...i'm running a 4-channel alpine amp currently for my 4 speakers...and i'm not too sure about my amp or amps for my subs...but most likely 2 amps for my subs, or 1 amp with those outputs (i'm not as familiar with subs/amps as i am with speakers/amps) i hope that information helps...
    Constant Bitrate Willy-Mach1's Avatar
    Mar 2005
    Laurel, Maryland
    I have the first one straight to my 4-ch amp for my speakers. I don't have subs, yet, but it works great with my four component speakers.....no hibernation issues either
    Progress: |##########| 99.99%
    - Tweaking and enjoying!!!! Never really done.....
    -= MachPuter Project =-
    -= MachPuter Project Worklog=-
    Apr 2005
    are there any more outputs on the card to support subs?
    Mar 2005
    Laurel, Maryland
    yes.....the card has three "headphone" jack outputs on the back.... front speakers, rear speakers, and subwoofer
    May 2009
    Quote Originally Posted by senseless228 View Post
    or even this one
    Hi,
    I want to know what will be the difference in the output while using the sound cards mentioned by you, to the onboard sound card.
    I am Using Intel DG45ID, it has on-board 7.1 channel Audio with SPDIF out as well.
    Presently i am using it with the aux-in in my head Unit. But when i tried it connecting the 3.5mm jack to the amp via rca the output was less, when compared to the aux in. so i decided to go with aux-in itself.
    SO what is the solution, or is there any problem anywhere.
    Jan 2008
    you have run into the problem that most of us run into-- computer sound cards rarely have enough voltage to actually drive a car amp(there are a couple here and there, but i haven't seen too many usb solutions).
    so you would need a preamp, or a headunit to boost the signal before the amp.
  1. How do I setup the CD Rip plugin ?
    By guino in forum RR FAQ
    Last Post: 12-18-2008, 07:28 AM
  2. Doing a carpc setup, questions/help
    By Punisher in forum General MP3Car Discussion
    Last Post: 08-28-2005, 12:44 PM
  3. help with my wifi setup?
    By ŠuTcH in forum Wireless Communications
    Last Post: 12-05-2004, 11:10 PM
