Results 1 to 6 of 6
Thread: Keeping Factory Radio (but not using it except FM)?
    Aug 2002
    California
    I'm helping a friend out (client too) with a carputer install. We decided to locate the screen in the center console and he wants to just leave the radio where it is on his 2000 Silverado. My question: is there away we can hook up the computer to run through an amp for the subs and then amp for the other speakers (unless we don't need this) while still being to use the stock radio when he wants? This would be easy as we would not need to worry about an FM solution on the computer. How would we accomplish this. I know we could use the AUX in but I think it would be cool to give him surround sound. Sorry if this has been asked before but I didn't see it.
    2003 Audi A4 1.8t (Totaled, Project Canceled)
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    i use my headunit as the main audio source, it hooks up to my amp...my computer feeds sound to my headunit. I have an auxilary port in my headunit. He might have a cd-changer adapter for his stock headunit...and with this you can accomplish this task. I dont see how he would not have surround with this option.
    PC Components:
    My work log
    Aug 2002
    California
    Quote Originally Posted by Peoples
    Isn't the Aux in just left/right where as a 4ch amp has has left/right-front and left/right-rear plus the seperate sub ch.
    Aug 2002
    California
    HOW TO: Get sound from PC to Car Stereo / Amp
    According to this I just pump the radio to the line in on the computer and it will forward the sound even if the computer is off...
    Admin
    Aug 2005
    my plan
    I'm planning something similar in my Toyota Tundra. I've already got the CarPC mounted mounted over the driveshaft hump, and although the whole unit is easily removable it still looks remarkably well integrated. At the moment, I have two separate complete systems -- the factory sound system is untouched, and the CarPC runs to a dedicated amp and speakers.
    The plan is to cut the front speaker wires from the head unit and run them through a speaker-level to line-level convertor, and then run this signal to the line-in jack on my soundcard. I'll upgrade the front speakers and drive them from a dedicated amp. I've already got the rear seat out (I've got the crew-cab model) and I'll be replacing that with a sub box. The rear factory speakers will remain unchanged, so I'll always be able to listen to the factory head unit through the rear factory speakers as a backup in case of PC failure.
    This system will allow me to do a bunch of cool things. I can use the PC as a TIVO for the radio, and I can mix the radio (the only thing I really use the radio for is NPR) over a music track.
    But the *real* reason I'm doing this is that I plan to do all of the active crossover equalization as digital filters in the PC. Essentially, I'll be using an 8-channel sound card running each channel to a dedicated amp channel, and then to a dedicated speaker. This way I can get a perfectly flat response from every speaker, and even actively tune the system depending on whether I'm driving alone or with a passenger.
    -p.
    Low Bitrate baudi's Avatar
    Feb 2006
    Arlington, VA
    gnomad, did you ever get your audio Tivo working? What software did you use?
  1. CarPC Remote control of FM Radio / Amplifier within Blaupunkt HU
    By ProCos in forum General Hardware Discussion
    Last Post: 05-28-2011, 10:56 AM
  2. FM radio on your PC solutions
    By linden_arden in forum General Hardware Discussion
    Last Post: 01-29-2005, 10:07 PM
  3. FM radio hell
    By turbochris in forum General Hardware Discussion
    Last Post: 09-03-2004, 11:17 PM
  4. FM radio Question
    By thepogcbr900rr in forum General Hardware Discussion
    Last Post: 05-09-2004, 07:27 PM
