Hey im installing a kenwood ddx in my 2005 altima and i have a bunch of wires aside from the obvious left over that i dont know where to connect. The first is a blue wire that the book says goes to the power antennea which i dont have and the other one is a yellow wire that says that it need to go to the battery. Now the harness already has a yello wire connected to it and i dont know should i connect both yello wires to the harness or should i run the yellow wire with the fuse that says 5v directly to the battery. If so where do i connect it to? Thanks for your hlep guys.
