Results 21 to 30 of 38
Thread: Too much bass for my pc case?
  1. #21
    Sep 2005
    Santa Barbara, CA
    XxAndyxX
    Not to threadjack, but did you remove your spare tire to make room for the the two subs? Seems like a good way to save space (if you're confident in your tires )
  2. #22
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    I saw a merc with the (one) sub in the wheel well, and the wheel "over it" so that the sub was seen through the spokes... looked nice, but the wheel was much "higher" than the standard... I guess cause the wheel well has a peak for the wheel spoke-area (middle area)
    Roy
    2005 Range Rover 4.4
  3. #23
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    Quote Originally Posted by bdrezner
    XxAndyxX
    I didn't have to remove it for the subs, but I did remove it to put a third amp there for my door speakers.
    Quote Originally Posted by RoyN
    The sub had some sort of cover over it right?
  4. #24
    São Paulo, Brazil
    no, the "spokes" of the wheel were like a cover for it....
    Code:
    (---|SUB|--)
    this is somewhat what it would be like, in a cut-out view...
    Roy
  5. #25
    Dec 2003
    Edmond, Oklahoma
    I still think exposing your sub to the outside environment is absolutely retarded.
  6. #26
    Oct 2004
    NY
    I think he means in the trunk
  7. #27
    São Paulo, Brazil
    Quote Originally Posted by XxAndyxX
    what are you on about??? hahaha it is in the trunk of an E series I think, or a C...
    Roy
  8. #28
    Oct 2004
    NY
    or at least I hope that's what he meant
  9. #29
    Dec 2003
    Edmond, Oklahoma
    Haha, I thought you meant you could see it from the outside of the car... Like the sub was facing outside of the wheel well. I wouldn't have thought that was what you meant unless I've actually seen an install where a guy cut two holes in the floor of his truck. He had both subs firing downward towards the ground, exposing his subs to all the elements.
  10. #30
    São Paulo, Brazil
    hehehe, no, this is a bit of a description:
    Open the trunk, look down.
    See the spare wheel, flush with the "floor" of the trunk around the wheel. Look at center of wheel (where the wheel cap is), and you can see that under the wheel there is a sub facing the trunk-lid.
    remove wheel up, sub is exposed, with a "embossed" edge around it, the size of the rubber of the tyre, so the tyre fits "around" the sub...
    Roy
  1. Painting Ampie Case
    By semovodka in forum General MP3Car Discussion
    Last Post: 10-08-2005, 05:37 PM
  2. Help with mounting PC case.
    By Nodotus in forum Fabrication
    Last Post: 08-30-2005, 02:11 AM
  3. Question about ITX-PD/3677 and 3688 DC Deck PC Case
    By m3rdpwr in forum General Hardware Discussion
    Last Post: 12-21-2003, 08:47 AM
  4. Book PC case
    By FreznoSmooth in forum General Hardware Discussion
    Last Post: 12-30-2000, 12:10 AM
  5. Book PC case
    Last Post: 12-16-2000, 11:23 PM
