Page 4 of 4 FirstFirst 1234
Results 31 to 38 of 38
Thread: Too much bass for my pc case?
  1. #31
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    Yeah, I get what your saying now, and I bet that looks good. Especially with a nice rim covering it.
  2. #32
    Variable Bitrate vxcarpc's Avatar
    Jan 2005
    Melbourne, Australia
    dude.. i run 2 X 12" kicker subs and i got my pc under them.. wrap the case in foam if you need shock protection.
    CAR INFO HERE
    "He who dies with the most toys, wins".
  3. #33
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Hmm... I had foam under my computer, "trying to absorb shock" since it was mounted at the worse possible location: over my rear wheel.... Got a good amount of freezes over potholes... (mounted horizontal HD)
    Then I changed the harddrive to vertical... about 80% improvement...
    now I bolted the carpc strongly to the car itself, no more "lag" movement, it is completely solid... not one crash/skip in 2 weeks...
    If you have it bolted on, the sub might be vibrating the air around it, but the HD/carpc is not going to move at all (I really dont think that the vibration will be able to get through the HD casing and such) since it is bolted...
    If you put it on foam or whatever, it will not be 100% solid, and will vibrate as well as the air around your subs = worse...
    so IMHO all this "foam it up", "it will be crap if you bolt it to the car", yada yada, is all non-true speculation... at first through, foam should "cushion the sub-pounding", but it is best to have the carpc bolted without independent movement from the car (the sub isnt pounding the entire car so there will be less movement by bolting it strongly to the car)
    Roy
    2005 Range Rover 4.4
  4. #34
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    The thing is...my subs are punding the entire car (especially the trunk), but I see what your saying about bolting it being better...I think ill try and find room on one of the sides of the trunk and maybe bolt it onto there after dynamating the surroundings so that the wall itself isnt vibrating as much...thanks for all the input guys...ill post pics when i get the chance
  5. #35
    São Paulo, Brazil
    Yeah, you could try to put a "foam barrier" to dampen the vibration before it reaches the carpc, but I wouldnt put the computer itself on foam..
    be very careful when "dampening" stuff around the carpc so you dont end up putting insulation that would make it worse to cool the pc...
    Roy
  6. #36
    Constant Bitrate minghi's Avatar
    May 2004
    Phoenixville, PA
    my experience over the last 2 years during which i had the same laptop in my car.
    - my shocks are really really bad and bumpy. the carputer survived it with no complains. its an ibm 6gb laptop hdd and it is mounted vertically with soft foam on all ends of the car and trust me, it survived so far.
    400W Power Amplifier -$25
    P3 laptop mobo-$30ish
    128MB RAM-$10
    6GB+80GB 2.5" HDDs-$130
    GPS-$60
    7" TS Lilliput-$280
    10" pioneer 500w sub-$55
    sony xm-3020 30W amp-$10
    jensen 340W A34XP amp-$40
    mp3car.com resources and members- priceless
  7. #37
    Tainted Love Cris's Avatar
    Romania
    So I guess the conclusion would be that bass doesn't affect the pc...
  8. #38
    Jul 2005
    Ontario
    damn looks good, dd anyone ever put 2 pubs behind the seat? like this
    ( = sub | = panel where sub is mounted \ = back on the seat in trunk
  1. Painting Ampie Case
    By semovodka in forum General MP3Car Discussion
    Last Post: 10-08-2005, 05:37 PM
  2. Help with mounting PC case.
    By Nodotus in forum Fabrication
    Last Post: 08-30-2005, 02:11 AM
  3. Question about ITX-PD/3677 and 3688 DC Deck PC Case
    By m3rdpwr in forum General Hardware Discussion
    Last Post: 12-21-2003, 08:47 AM
  4. Book PC case
    By FreznoSmooth in forum General Hardware Discussion
    Last Post: 12-30-2000, 12:10 AM
  5. Book PC case
    Last Post: 12-16-2000, 11:23 PM
