Results 1 to 6 of 6
Thread: Crackling from tweeters
    Oct 2005
    Hi, i am a newbie here so plz be nice
    Ive recently installed my car pc and screen etc. I am running:
    VIA EPIA M 10000 LVDS Motherboard and 256MB DIMM of PC3200 memory with 40Gb hd drive and slotload dvd/cdrw optical.
    Problem- wen i play audio from the pc thru my stereo's aux in, i am getting crackling from my tweeters....this is only on certain songs, however on the songs it happens on, its bad!
    - The tracks themselves are fine, this has been tested.
    - I have tested the same problem tracks with winamp and windows media player and also using Mobile Impact, crackling happens with each.
    - I have a ground loop isolator which has stopped the initial whining i experienced.
    Any advice would be much appreciated.
    Many thanks
    Dave
    Jul 2000
    Hampton, GA , USA
    Sounds like your signal going in to the Aux is a little too hot. Back off your Master volume on the sound card and see if that clears up the songs.
    Steve
    System Status - Starting Over
    Computer: None
    Vehicle: Silver 2002 Malibu
    Oct 2005
    i just gave that a quick go m8, it did somthing but obv that makes the stereo work harder too....the quieter the pc volume is, the deeper the distortion sounds, whereas wen the master volume is up high the tweeters distort much more high pitch crackly like.
    Could it be a drivers issue? or maybe even because im only using on board sound?
    Cheers
    Dave
    Apr 2005
    Queens, New York
    dont use onboard audio! I have used it, and it sucks! GO with a PCI card or an external usb!
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Oct 2005
    wot happened wen u used ur onboard audio? Same as me or something diff?
    Can u recommend a decent but fairly priced audio card which will fit in my mini-itx case or if not and external usb one?
    btw my in-house pc has a creative labs sound blaster 5.1 card....recon that'd fit?
    Cheers
    Dave
    Apr 2005
    Queens, New York
    Quote Originally Posted by dave_corsa
    Cheers
    Dave
    It just sounded like crap! I have a sound Blaster Audigy 2 NX. it is an external usb sound card, and it works very very good!
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  1. DVD mp3 playback crackling
    By barney0001 in forum General Hardware Discussion
    Last Post: 07-22-2006, 09:03 PM
  2. Tweeters work, mids don't
    By omehegan in forum Car Audio
    Last Post: 09-18-2005, 04:12 PM
  3. Replies: 13
    Last Post: 08-29-2005, 06:21 PM
  4. Aiming components and tweeters
    By Psychobiker in forum Car Audio
    Last Post: 07-25-2005, 09:15 PM
  5. (2) Pioneer coaxials w/ blown tweeters
    By greenman100 in forum Classified Archive
    Last Post: 05-10-2005, 03:12 PM
