Results 1 to 10 of 15
Thread: External USB Soundcards...
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    I have searched around here but there seems to be no conclusive threads/posts on the subject...
    I wanted to get an external USB card, fix it near to my amps, and feed straight RCA from the soundcard to the amps.
    I saw this Maya EX soundcard... I like it because it has 6 RCA outputs, 2 RCA inputs (could I attach a mic to this?! would I need a 2.5mm pin->2rca y cable?), and an extra mic input/digital input.
    Closeup image of the card: http://www.audiotrak.net/at_library/...oseup_port.jpg
    Specs: http://www.audiotrak.net/mayaex.htm
    Any ideas on how this compares with the Soundblasters? What is generally the good/best usb soundblaster around?
    I wonder if the Maya will work with kxproject drivers, or if the maya oned are as good as the kxproject ones (prolly not)
    Please feel free to chime in with other brands..../models... if they get their power from the bus its a plus...
    Roy
    2005 Range Rover 4.4
    Jul 1999
    Birmingham, Alabama (War Eagle!)
    RoyN, that MayaEx looks awesome, however, I'm scared that I may run into the same problem I have now with my external SB 24bit usb.. that is, my amp for the 5th channel (sub channel) requires a straight up mono connection, so I would for that card to be front left/right, rear left/right, sub mono, and then a spare one for center channel may be nifty.
    Good Luck w/ the search.
    São Paulo, Brazil
    Well, if I am not mistaken, the 6 RCS outputs can be mapped as you wish...
    1 for each speaker (4 + center optional), and 1 for sub (mono)...
    However, even if you have a 2 channel output for the sub, you can always use a Y cable and join the signal into mono... you should be careful though, you dont want to mix the center channel and the sum together (since when using 5.1 they are usually on the same output pin.
    I wonder if the maya can do 4.1 also...
    Roy
    gbh
    gbh is offline
    Constant Bitrate gbh's Avatar
    Oct 2005
    Massachusetts, USA
    RoyN posted: 2 RCA inputs (could I attach a mic to this?! would I need a 2.5mm pin->2rca y cable?),
    I think you need a small voltage applied to the rca inputs like the voltage on a line out from a stereo, dvd player, etc. I think you would need to go mic>pre-amp>rca.
    I think that sound card looks cool though!
    FLAC arebelspy's Avatar
    Sep 2005
    San Luis Obispo, CA
    How about this:
    http://www.geeks.com/details.asp?inv...&cpc=SCH&srm=0
    Looks decent, I'm just scared of the you get what you pay for law.. $19 is cheap..
    -arebelspy
    See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
    Quote Originally Posted by xdjxklusivex
    i think every thread is now a whoreing thread
    Constant Bitrate Willy-Mach1's Avatar
    Mar 2005
    Laurel, Maryland
    I use th USB Soundblaster Live! 24-bit. I've had no problems with it at all. I've read of quite a bunch of people having trouble with the Audigys though. The card does not have RCA outputs but it has regular headphone-type jacks which are easily converted to RCA. it has an output for Front, one for rear, one for sub; inputs are line-in, and mic. It also has an optical out. It does 4.1 and is bus powered. I think this is a pretty good card, although that Maya looks nice too.
    Progress: |##########| 99.99%
    - Tweaking and enjoying!!!! Never really done.....
    -= MachPuter Project =-
    -= MachPuter Project Worklog=-
    May 2004
    NJ
    Quote Originally Posted by Willy-Mach1
    It has 5.1, the center/sub are on the same jack - I have it, suspend/hibernate is non-issue with it.
    São Paulo, Brazil
    @kingtut, can i use 4.1 instead of 5.1? (Will the software split the center channel into the front channels? otherwise movies and stuff made with center channels sound like crap, it issnt just setting 5.1 and ignoring the center channel)
    Roy
    FLAC -zip-'s Avatar
    Ontario/Canada
    I have an Audigy NX 2 I think its great. My set up is a little differend from what you want to accomplish - S/PDIF to H/U, TOS-LINK to Sirrius, mic for Navi Voice.
    Never had a problem, other than my son lost one of the volume knobs, but is sounds fantastic. Very reliable and have never had issues with sound in anyway, I have a dedicated USB port for it.
    I have also heard good things about M Audio, did you check them out?
    Also I dont see any sound shapeing software for time delays, X-overs (ones on amps are very minimal)., PEQ etc.
    Sound Stage
    Eclipse|MTX|Infinity
    Mar 2005
    Laurel, Maryland
    Quote Originally Posted by kingtut
    @kingtut - I know it does 5.1, I was just confirming that it does do 4.1 too which is what RoyN is looking for,
    Quote Originally Posted by RoyN
    @RoyN - that is how I have mine set up and it works great, and like kingtut, I do not have any standby/hibernation issues.
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 08:35 PM
  2. Creative Labs Sound Blaster® Live!™ 24-Bit External USB 1.1
    By SpyderHatch in forum Classified Archive
    Last Post: 11-28-2005, 04:12 PM
  3. Replies: 2
    Last Post: 03-15-2005, 01:37 PM
  4. Replies: 10
    Last Post: 12-20-2004, 12:15 PM
  5. 2 external laptop hd enclosures FS USB 2.0
    By outragis in forum Classified Archive
    Last Post: 03-11-2004, 05:05 PM
