Results 1 to 7 of 7
Thread: Do I have this right?
    Nov 2005
    London, Ontario, Canada
    I have a panasonic head unit and I will be getting a touchscreen.
    I alos have an amp for my subs and an amp for my 4 speakers.
    So, if I have a computer, I just jack the sound card from the PC into an input into the headunit, and whatever I do on the PC, will play through the
    speakers?
    Sound right?
    Oct 2004
    NY
    yep.... sounds right
    Constant Bitrate takissd's Avatar
    May 2004
    San Diego, CA
    that's exactly how i have done it with my carpc. Also cable that turns on/off the amp is the one that turn's on/off the pc (accessory on/off NOT dedicated +12V or ground )
    -VIA EPIA M10000/512MB/40GB HD
    -DWW motorized 7'
    -BU 303 GPS w/iGuidance/ CF
    -Opus90w
    -Belkin Bluetooth
    -Pioneer HU
    [||||||||||] 95% done
    Nov 2005
    awesome!
    so will a good sound card affect this?
    or do i just need any card with an RCA output?
    FLAC -zip-'s Avatar
    Ontario/Canada
    If your Aux port on your H/U supports an optical connection use it.
    Sound Stage
    Eclipse|MTX|Infinity
    Nov 2005
    optical?
    ummm im not sure what you mean by that?
    what kind of connection is an optical cable?
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Optical Port (has to be on both PC and Head-Unit):
    Must be used with an optical cable:
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
