Page 11 of 15 FirstFirst ... 23456789101112131415 LastLast
Results 101 to 110 of 145
Thread: List Of 5.1/optical Amps
  1. #101
    May 2005
    PNW
    But the Alpine REQUIRES an Ai-Net connection via the head unit or controller, right?
    Just want to make sure I understand all this before dropping some $$$ into it.
  2. #102
    _
    Mar 2004
    Little Elm, Texas
    let me see if I understand what's going on here
    Regarding the two units
    The Alpine requires a controller
    The Clarion requires a controller
    The Alpine takes in an optic signal and spits out an analog signal
    The Clarion takes in an optic signal and spits out an analog signal
    The Alpine has a 31-band EQ as well as a Parametric EQ
    The Clarion only has a small Parametric EQ
    The only upside to the Clarion is that it's less expensive than the Alpine
    The downside is the Clarion's display looks super cheap (sorry guys, but it does) and the fact that it just doesn't have the same tuneability as the Alpine
    This is the way I'm seeing this, does anyone see something that I'm seeing as wrong?
    Jan Bennett
  3. #103
    May 2005
    PNW
    I thought the whole thing was that the Clarion doesn't need a controller. Did I miss something?
  4. #104
    _
    Mar 2004
    Little Elm, Texas
    http://www.cardomain.com/item/CLADVH940
    The DVH940 can be controlled by select Clarion CeNET in-dash monitors and receivers, or the optional DVC920 stand-alone universal controller.
    The big deal is that the connection that would send a signal INTO the unit was optical and was a propritary connection made by Clarion specifically for Clarion Head Units. The original guy that posted about this finally working, just chopped off the HU end of that cable and plugged it into his computer. Now all he's got to do is adapt a regular tos-link end to the end that he cut up.
    Make sense?
    Someone PLEASE correct me if I'm wrong!
    Jan Bennett
  5. #105
    May 2005
    PNW
    I thought the whole point was that it could be "Stand-Alone". To add more confusion to this, , here's a pic from the users manual for the DVC940:
    So, leaving the switch in "Slave Mode" leads me to believe it can run independant of a controller. Maybe not, I don't know.
  6. #106
    _
    Mar 2004
    Little Elm, Texas
    I can see where you're coming from, but then I ask, how would you controll it?
    via the computer?
    it doesn't come with software....
    Jan Bennett
  7. #107
    May 2005
    PNW
    Sure, control it though the computer.
    If you have a sound card that can adjust levels, then output the signal in some sort of encoded signal (Dolby Dig, DTS, etc), then have it go to this unit... have it decode it via the firmware on the unit supplied by Dolby labs and Digital Theater Systems... then output via RCA to an amp... that's what would make sense for me. Since I don't have any experience with mobile processors, only home theater systems, I don't really know what the controller does.
    It would makes sense to me to control the signal from the source, not another piece of hardware that may not be necessary. In the mobile theater market... sure, a controller may make sense. You could adjust levels and such I suppose. But, we already have that in the computer. We've all paid for that already.
    <-- n00b.
  8. #108
    Constant Bitrate chuyler1's Avatar
    Feb 2006
    Massachusetts
    Quote Originally Posted by Red GTi VR6
    That about sums it up. If you are looking for something w/o a head unit then the clarion is the cheaper of the two. If you are looking for something with a head unit....at least you know you have an option from both brands although the 31-band EQ gives the alpine a significant advantage. I tend to lean towards clarion when it comes to head units but that's me.
    This is debatable, but from the reviews I've read (past and present) Clarion tends to have the edge on SQ when it comes to head units and DACs. I read a recent online review comparing the DRZ9255 to the F1 DVI-9990 and other high-end units and the DRZ had the most unbelievable sound stage where the speakers actually dissapeared. Whether the DVH940 can compete with that is another story of course.
  9. #109
    _
    Mar 2004
    Little Elm, Texas
    but the alpine doesn't use a HU, it uses a controller just like the clarion...
    OR it can use a HU just like the clarion
    not sure if this is what you are saying in your post or not...
    Jan Bennett
  10. #110
    Feb 2006
    Massachusetts
    Both require some sort of controller, whether it's a HU or stand-alone. Something has to be in your dash (or mounted somewhere). So it boils down to SQ, features, and price. The Clarion wins with price but the Alpine wins with features.
  1. thumbnail view for folder and list view for file?
    By civic5zigen in forum Road Runner
    Last Post: 11-01-2005, 12:55 AM
  2. Audigy2 ZS to four amps... few questions.
    By luckydevil in forum General Hardware Discussion
    Last Post: 10-08-2005, 07:38 PM
  3. Amps Protecting at high volumes
    By kdunn926 in forum Car Audio
    Last Post: 08-30-2005, 09:14 PM
  4. "state of the art" parts list?
    By kbyrd in forum Newbie
    Last Post: 04-29-2005, 11:35 AM
  5. Replies: 13
    Last Post: 04-15-2005, 02:55 PM
