Page 4 of 15 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 145
Thread: List Of 5.1/optical Amps
  1. #31
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Scouse Monkey
    Blaupunkt do one.
    do you have a link to this?
    I've just searched their site and can't find an amplifier from them with an optical input.
    Jan Bennett
  2. #32
    _
    Mar 2004
    Little Elm, Texas
    ok - I did a little bit of looking for info on the listed amplifiers and this is what I've come up with:
    1. Hifonics Zeus ZX 5.1
    This amplifier appears to be discontinued. It can probably be found used.
    2. Phoenix Gold Octane-R R5.1MT
    Here is a link to the manual for this piece: http://www.n-core.se/products/PG/Oct...1MT_manual.pdf
    Specs are as follows:
    Front and Center Channels:
    100 watts x 5 @ 4 ohm stereo @ 14.4v (max power)
    50 watts x 5 @ 4 ohm stereo @ 14.4v (RMS power)
    18 watts x 5 @ 4 ohm stereo @ 12.5v
    Subwoofer Channel
    200 watts x 1 @ 4 ohm @ 14.4v (max power)
    100 watts x 1 @ 4 ohm @ 14.4v (RMS power)
    36 watts x 1 @ 4 ohm @ 12.5v
    This amplifier is only stable at 4 ohms. This amplifier will not work for situations where the system calls for a lower ohm load.
    3. Performance Teknique ICBM-5.1 5.1
    5.1 High Power Amplifier 2000W Max
    Dolby Digital 5.1 Decoding
    Pro Logic Decoding
    1-Optical Input
    1-Coaxial Input
    A-Aux Input (Stereo): Max 2 Vrms
    High Quality 24 bit ADC and DAC's
    Dynamic Range: >100db ( on decoder line output )
    Sub Speaker on/off switch
    Center Speaker on/off switch
    6Channel Level Control: +- 10db in 1 db step
    Master Volume control
    Selectable crossover filters: 40hz - 240hz in 10db step
    Stop band slope of LPF: 24db Octave
    Stats:
    Front / Rear / Center Power @ 2 ohms: 100 Watts x 5
    Subwoofer power @ 2 ohm : 360 Watts x 1
    Frequency responce: 10 hz - 30,000 hz
    THD: < 0.05%
    S/N: >120db
    Channel Separation: 80db
    Variable Low and High Pass Filters
    Fuse rating: 30A x 3
    MSRP: $599.99
    4. Alpine MRA-D550
    The MRA-D550, 5-channel amplifier combines an amp and a multi-channel surround sound digital processor in to one unit.
    http://www.alpine-usa.com/en/product...model=MRA-D550
    Owners Manual:
    http://www.alpine-usa.com/images/pro...RA-D550_om.pdf
    FEATURES
    • 2-Optical Input
    • 4 Volt PreOut
    • Ai-NET and RCA Input
    • Amplifier Link Ready
    • Bass Engineฎ DSP(6-ch Manual Time Correction, 31-Band Graphic EQ and Media Xpander)
    • Blue Power Indicator
    • DTS
    • Dolby Digital
    • Dolby Pro Logic II
    • Integrated Wire and Mounting Screw Covers
    • STAR Technology
    • Thermal Managment Processor
    • V12 AccuClass-D™ Design
    • Variable Turn-On Delay
    CEA-2006 Power Rating
    CEA-2006 Power Rating ([email protected] = 1%THD+N), S/N 80dBA (Ref. 1W into 4Ohm): 60W x 5
    RMS Power (at 12V,20Hz-200Hz)
    Per Channel into 4Ohms (•1% THD+N) : 45W x 5
    Per channel into 4 ohms : 45W x 5
    MSRP: $900.00
    5. Alpine MRA-F350
    All you have to do is add an Alpine compatible source unit.
    http://www.alpine-usa.com/en/product...model=MRA-F350
    Owners Manual:
    http://www.alpine-usa.com/images/pro...RA-F350_om.pdf
    FEATURES
    • Crossover (HP/LP)
    • 5 Channel Operation
    • Adjustable Crossover (HP/LP)
    • Auto Overcurrent Protection
    • Bass Engineฎ
    • Bass Management
    • Cross-Vented Chassis Design
    • DC-DC PWM Power Supply
    • Darlington Bi-Polar Outputs
    • Discrete Pre-Amp Stage
    • Gold Plated Power Screw Terminals
    • Gold Plated RCA Jacks
    • Gold Plated Speaker Terminals
    • MOSFET Power Supply
    • Manual Time Correction
    • Non-Fading Pre-Amp Output
    • Parametric Equalizer
    • Phase Selector
    • STAR Circuitry
    • Solid Copper Bus Bars
    • Subsonic Filter
    • Top Mounted Blue LED Power/Status Indicator
    • Triple Darlington in Push-Pull Configuration
    CEA-2006 Power Rating ([email protected] = 1%THD+N), S/N 80dBA (Ref. 1W into 4Ohm): 50W x 5
    6. Autosonik AA.6900 - 7690 068
    http://www.autosonik.com/asp/multime...PLIFIERS&ID=23
    Features: 6 channel amplifier with Dolby Digital, DTS and prologic processor built inside. Gain control, crossover control, OSD, remote control, IR sensor.
    A Google search of this amplifier yields the above link and a link to a thread in the MP3car.com forums. That’s it.
    7. Focal FP Dual Monitor
    This is one bad *** amplifier.
    No prices yet.
    http://www.focal.tm.fr/car/en/index.htm
    Nominal power measured at 13.8V continuously @ 4 ohms: 2x300W RMS
    Nominal power measured at 13.8V continuously @ 2 ohms: 2x400W RMS
    Power in bridged mode measured at 13.8V continuously @ 4 ohms: 1x800W RMS
    Power in bridged mode measured at 13.8V continuously @ 2 ohms: 1x1200W RMS
    Power supplies Dual fully regulated
    Signal/noise ratio >110dB (A)
    Damping factor at 4 ohms >600
    Frequency response (-1dB) 10Hz-45Hz
    Input impedance 13kohms
    Input sensitivity 0.2-5V
    Digital inputs Coaxial/optical
    Output stages Triple Darligton
    Operational amplifiers Burr-Brown
    DSP 2 internal DSP
    180 mips each
    Converters 24-bit/96kHz
    Crystalฎ
    Software Provided
    Remote control Provided (gain+5 presets)
    Digital graphic EQ (each input channel)
    30 bands of 1/3 octave
    Digital delay line (each input and output channels)
    2 inputs and 2 outputs, 2048 samples max.
    Digital control From external PC via USB port
    High-pass crossover Slopes and frequencies fully adjustable
    Low-pass crossover Slopes and frequencies fully adjustable
    Digital parametric EQ 1 band fully adjustable
    Maximum cross section of loudspeaker cables 10mm = 7 AWG
    Maximum cross section of power cables 51mm = 0AWG
    Protections DC offset
    Short-circuit
    Continuous power
    Thermal overload
    Soft clipping
    Over voltage
    Polarity error
    Dimensions (HxWxD) 50x540x280mm (2x21.25x11“)
    Weight 7.5kg (16.53 lb)
    8. Pioneer DEQ-P7650
    MOSFET 50Wx5. Multi-Channel Processor with Auto EQ & Time Alignment
    Features
    • Built-in DTS / Dolby Digital / Dolby Pro Logic II / Linear PCM decoder
    • 6-ch. DAC
    • 5-ch. built-in amplifier
    • SFC for multi-channel source
    • Built-in 6-ch. DSP
      o 7-mode preset equalizer
      o 2-mode custom preset equalizer
      o Multi-Channel Auto EQ
      o Digital SFC (Sound Field Control): 6-mode (Musical/Drama/Action/Jazz/Hall/Club)
      o Digital listening position selector
      o Auto Time Alignment
    • Optimum sound for car environment
      o Dynamic range control
      o Optimum down-mix for normal speaker layout
    • Bulti-in crossover network (L/R)
      o Crossover frequency: 63/80/100/125/160/200Hz
    • High-voltage preout (5V)
    • IP-Bus input/output
    • 6-ch. RCA preouts
    • A/V inputs
      o 2 RCA Audio inputs
      o Dual optical inputs for DTS / Dolby Digital / Dolby Pro Logic II / Linear PCM
    Jan Bennett
  3. #33
    May 2005
    PNW
    I just got off the phone with Alpine Technical Support, and they told me that you have to have an Alpine-branded DSP for both the MRA-F350 AND the MRA-D550. Looking at the manual for the MRA-D550, it says:
    "Important
    This unit cannot be turned on or operated unless the
    Ai-NET compatible head unit (IVA-D300, IVA-D901 or
    IVA-D900, etc.) is connected."
    So, is there any way to mimic having a Ai-NET head unit via the PC?
  4. #34
    _
    Mar 2004
    Little Elm, Texas
    you didn't have to call them, it tells you that on their web site
    Jan Bennett
  5. #35
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    So, which one does it need?....an alpine DSP or an alpine head unit (with ai-net). I'm guessing that it just needs the head unit.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  6. #36
    _
    Mar 2004
    Little Elm, Texas
    they can probably use either....by dsp, meaning the 701 or the like...
    Jan Bennett
  7. #37
    May 2005
    PNW
    Quote Originally Posted by Red GTi VR6
    OK. Just wanted to make sure.
    So, do you know of any way to get these amps to work with a carputer? I don't want to run a seperate DSP if I don't need to.
  8. #38
    _
    Mar 2004
    Little Elm, Texas
    eh - without hacking it, not sure...
    do a search - I know some people were trying it a while back, post up the link when you find it - I gotta run and get lunch otherwise I'd search it
    Jan Bennett
  9. #39
    Jan 2005
    Pure Digital Amp
    If you want a pure digital amp, this is it.
    http://tbk.co.kr/eng/products_soluti...um=2&idorder=1
    No DAC. Strictly digital all the way through.
    Muritzy makes it.
  10. #40
    Aug 2005
    Anaheim Hills, Ca
    I've seen that amp before...looks like a sweet amp. I wonder if it needs a controller or compatible head unit like the alpine.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  1. thumbnail view for folder and list view for file?
    By civic5zigen in forum Road Runner
    Last Post: 11-01-2005, 01:55 AM
  2. Audigy2 ZS to four amps... few questions.
    By luckydevil in forum General Hardware Discussion
    Last Post: 10-08-2005, 08:38 PM
  3. Amps Protecting at high volumes
    By kdunn926 in forum Car Audio
    Last Post: 08-30-2005, 10:14 PM
  4. "state of the art" parts list?
    By kbyrd in forum Newbie
    Last Post: 04-29-2005, 12:35 PM
  5. Replies: 13
    Last Post: 04-15-2005, 03:55 PM
