Thermic tape?Originally Posted by tj!2k4
J/K
Thanatos.
BTW TJ... no calculator app for me??![]()
use cable taps:
http://www.radioshack.com/product/in...entPage=family
Thanatos.
J/K
Thanatos.
sorry. i tried....Originally Posted by thanatos106
D'oh!! I forgot about decompiling calculator swf! I see DiNASTY made another calculator. Check it out; if you still want me to modify the other one, PM me and I'll get on it. Sorry bout that.![]()
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
That looks like a cool product, but I don't see how it would work because..
> the ford wire harness has a small pin at the end of each wire that is very small. some of them are broken and out of the harness
>it is questionable if the harness would still work as its somewhat broken
>the wires that run to the harness, well some of them running from the harness are too short and/or missing the special pins
we tried going to crappy tire and buying a harness just to take the pins out of them but they are the wrong ones.
i need an actual new harness to solder the wiring to
I'd pay for it, of course
You won't have any luck hooking up the speakers behint the deck. You amp is in your trunk right by the antennal. Pull the carpet away and, Whala. wire colors-http://www.installdr.com/Harnesses/Ford-Wiring.pdf
We already hooked up the speakers. They were simple. That is where the stock amp is, yes.
We already tried that site and the colors are wrong for the heating system and of no use at all. Ford still can't get me the right wiring harness and I will just keep going to different junkyards until I find the right one.
This harness is used for aftermarket decks. You can get it at any local car stereo store.
http://bestkits.com/SearchResults.as...000%20-%202003
It's been months, and I'm still not able to find this harness I need for my car. I'm going to explain a few things, including why it is so hard to find, and times when I thought I had fixed the problem but I hadn't.
- My "friend" yanked the harness, the stock harness that runs from the heating unit, while he was attempting to put a new aftermarket deck in for me. The harness that someone posted from this URL http://bestkits.com/SearchResults.as...000%20-%202003
that's just a harness that connects from the stock harness to the aftermarket system. The problem is the STOCK HARNESS - I have looked high and low and found nothing. I bought a harness from Ford and paid $80 for it, which wasnt the right harness. I couldnt take that one back because the label reads once its open it cant be returned.
Ive called Ford, who told me to call a wholesaler called Green Sales in the US, which didnt have the harness. Ive called lots of auto wreckers in Ontario and am still unable to find the harness.
Ford said they would fix the harness for me, which they wanted to charge me $100/hr for. This harness is so hard to find because its a digital one that is only in the tauruses with digital dashes - the SELs and etc.
If anyone has this Luxury wiring harness, the one for the diigtal display system, please let me know where I can find it.
Plz dont send me URLs of aftermarket harnesses which arent it. I likely will be taking a picture of the harness soon and posting it here
As mentioned before, cut the wires and connect them together.Originally Posted by markis00
And that link doesnt work because you didnt post it well.
