Need help with a Ford Taurus 2002 stock stereo
Hi all,
I am new to the forum and am looking for some help re: my Ford Taurus 2002 stock stereo. Now - here's the thing. As you may or may not know, the heating control panel and the stock deck are all connected on these Fords and they are BUGGERS to get out. I took mine out but the heating no longer works, and it won't for now but I will figure out how to get that part working later. This is because this one big piece is one big circuit board so if you try to seperate the two pieces or simply remove the deck the heating will not work either.
We managed to actually get the heat working by trying to connect some wires together. Two of them turned on the heat before burning and blowing a fuse!
Anyways, we've got a whole junkload of wires running to behind where the deck was, and for now we just want to hook up the deck. Likely once we get that going we can figure out how to turn the heat on and off by connecting wires together...
there are so many wires, green, blue, red, grey, yellow, list goes on and we need to know which wires run from which stock speakers. Either that or we blow away the entire stock system and re-wire the whole car which would be aggravating and expensive.
Please, if anyone knows where I can get a wiring diagram please let me know. Thanks!
