bump with 38 views and no replies
hey guys i wanna know if this will solve the low voltage outputs that would go to my amps. heres my setup.
1- still working on the carpc, maybe ill use my home pc that has a soundblaster live 24 bit which sounds good to me . which has one speaker jack out to a 5.1 speaker system.
2- its going to go into my single cab f-150 i will have a pair of components and 1 sub. then a kicker 350x2 for the cmponents. and a kicker 600x1 for the sub.im only using one set of components since its a single cab.
now the issue ive been having is if my system will sound good with a computer or not. i was seeing that people take the output from a decent sound card into a digital sound processor. well my question is
will this do fine for my system since 300 bux for a processor is alot and for that ill buy a headunit and this is msrp $79
http://www.mobilesoundworks.com/Prod...roductCode=kx2
its a crossover from kicker which is perfect. i think it will bump up the voltage of the signal from the computer which is the reason i need it. then it has a 2 rca input which ill use a splitter from the back of my pc audio out and plug it in there. then it has a high pass rca's for my component amp and a low pass rca's for my sub amp. all opinions welcome and sorry to whore.
that should work for you. I have a low pass crossover a lot like that on mine and it sounds great.
Randell Kelly
so it will bump up the very low output on my cards to more than 2v to my amps right?
or do i just need a line driver.
also this crossover is a line driver too right?
5V should be more than enough for your amps.Originally Posted by WEBSITE
