When u say "can this DSP be used with non-digital amps?" u mean amps that take analog input? if thats the Question then yes. This DSP outputs 6 (5.1) separate analog channels (RCA) ONLY so u use amps with analog input.
No need for a line driver if u use the Optical SPDIF (TOSLINK). I don't know if u need one if u are going to use the Analog input(2 channel).Also, If I use the Panasonic DSP, will I need a line driver since my soundcard has very low outputs, or will the Panasonic amplify the signal on its own?
I have this DSP and i plan on using it's Optical input and connecting it to the Turtle Beach Audio Advantage Micro 5.1 . I don't want to use bigger sound cards or an Digital RCA to Optical converter
LinkBack URL
About LinkBacks
