this is not gonna be easy. If you have two devices playing to the same amp/speaker, the signal doesn't know which way to travel. When it signal hits a junction it doesn't know whether to go towards the other sound source or towards the speaker. It will try to go both ways, so if you have two sounds devices, they might interfere with each other. I know that when i had a HU and a CARPC hooked up at the same time it made a hideous noise, the noise only disappeared when one device wa hooked up at a time,
im no expert, but you might be able to pull it off with diodes, but that may drop the voltage too much
LinkBack URL
About LinkBacks
