Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Soundcard with Dolby Digital Live and DTS!
  1. #11
    Newbie millc5's Avatar
    Nov 2005
    CA
    Quote Originally Posted by Fenrir
    ENCODING DTS/Dolby Digital is ONLY usefull if you want to try and send 5.1 signal over digital optical or coaxial. If you have 5.1 channel output on your soundcard, almost ANY DVD program can decode a DTS or Dolby Digital signal to analogue outputs, and use RCA in on your amps.
    The reasons people are interested in digital encoded signals are mainly for noise isolation and minimizing the number of connections. If you don't care about those, you don't need DTS/DDL.
    This is correct, I am feeding the AMP via optical cable, and it does decode the DTS/DOLBY 5.1 signal at the AMP. If my amp did not happen to have this feature, I would not miss it
  2. #12
    _
    Mar 2004
    Little Elm, Texas
    nice on the Zeus, but IIRC, this amp isn't avaliable any more, and if it is, it's not readily avaliable anywhere I've seen (especially over on this side of the pond)
    Jan Bennett
  3. #13
    _
    Mar 2004
    Little Elm, Texas
    btw - am I the only one who can't get the original link to work?
    Jan Bennett
  4. #14
    Nov 2005
    CA
    Quote Originally Posted by Red GTi VR6
    Its made by MAXXSONICS, I was told it will be reintroduced under thier AUTOTEK brand with added sub control knob, etc. Not sure what model number will be or when they will release the updated version.
    By the way, Fry's electronics carried them in California. May still be able to find one.
    heres one on ebay for example; not sure about seller...
    http://cgi.ebay.com/Hifonics-Zeus-5-...QQcmdZViewItem
    Oh, and the original link is broke for me as well.
  5. #15
    May 2005
    PNW
    Yeah, Bluegears has since gotten purchased by Auzentech. I got one of the cards, and it sounds incredible. I'll try and find the original item link and post it.
