Results 1 to 3 of 3
Thread: I think i blew my amp?
    Aug 2005
    CA
    So installed an alpine 5-channel amp the other day. Its a 4-channel amp plus sub driver. I built my own custom pc enclosure and forgot to ground the powersupply to the chassis so i ended up getting a big ground loop. I think i blew the sub channel on my amp. Does anybody know if this is possible. or how i can check to see if this is what happened. The rest of the amp works, just not the sub channel anymore. thanks for your help.
    _
    Mar 2004
    Little Elm, Texas
    it is possible to blow that channel on it's own.
    Several 5 channel amps out there use a class a or class AB (usually AB) for the 4-channel and a seperate class d for the sub channel.
    Do you happen to know which series/model etc amp?
    other than making sure your sub isn't blown (take another sub and plug it into that channel) and / or ditching the wire that's connecting the channel and sub currently to make sure it's not a wire issue....not sure how else you would test it on your own.
    Jan Bennett
    Dec 2005
    Need more details on the setup and what works/what dosn't work and what you want done for a proper diagnostics.
  1. Replies: 94
    Last Post: 09-13-2011, 06:59 PM
  2. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  3. vw mk4 monson amp and another amp
    By colorless in forum Car Audio
    Last Post: 10-03-2005, 01:32 PM
  4. Replies: 11
    Last Post: 05-27-2005, 11:25 AM
  5. My Amp Blew My Sub!
    By chewiee in forum Car Audio
    Last Post: 11-05-2004, 07:11 PM
