Results 1 to 3 of 3
Thread: Howto Trick Panasonic CQ-DFX10N?
    Jun 2002
    Norway
    Hi!
    Im trying to trick my headunit in thinking that I have an CD changer unit connected to it, so that I can use the CD-in signal for my Carputer. Iwe aquired all the needed Service manuals for bot CD-changer (CX-DP801EUC) and Head unit (CQ-DFX100N) both from Panasonic.. see picture..
    I cant seem to figure out how the head unit "sences" the cd-changer or how to enable the "CD-changer input" on sources.. ATM I have:
    Radio --> CD Player
    I want it to enable the CD-changer Input.
    Radio --> CD Player --> CD-Changer (CD-In)
    (Click to enlarge) warning!, large download! (approx 2 - 3MB per picture)
    Main Block: Head unit
    Main Block: Cd-Changer #1
    Main Block: Cd-Changer #2
    Can anyone tell me how the 8 Pin Cd changer connector works on this headunit?, is an resistor on some of the pins, some voltage of some kind?, or just a simple jumper would do the trick in fooling this headunit to think that a CD-changer is connected? ...
    Best regards
    Richard
    "If A equals success, then the formula is: A=X+Y+Z. X is work. Y is play. Z is keep your mouth shut."
    Albert Einstein
    The Panasonic(matsu****a actually) unit in my 2001 Audi uses an actual protocol to tell the headunit it is there. It isn't a simple physical connection that does it.
    If there isn't a PIE adapater or similar out there for your unit, you are going to have a hard time accomplishing this.
    Jun 2002
    Norway
    I kinda didnt want to hear that
    It would work If I got a cheap, used CD-changer.... and plug it in.. .but.. .hell...
    If anyone else has ideas if this could be done... please tell
    Richard
    Albert Einstein
