That is some very usefull info!
Beats having to add an external soundcard!
I thought I should share this interesting information for those using the SPDIF output of their EPIA board, like mox and myself.
We both noticed that some noise and hiss appears in certain conditions, even if the original sound quality is very good, and it seems we're not alone : this article suggests switching from the Via driver to the RealTek one on an Epia M9000, and I guess it should work with other similar models.
I have no way of testing this driver right now as I am reshaping my CarPC, but feel free to tell us if you test it...
Just my 2 cents.
Great thanks!
Great find! Will try ASAP, I am at work right now. Strange that nobody else on mp3car.com has ever reported this problem.
CarPC status: HW all done, SW needs tweaked.
Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
Software: RR, MM/FD
Never seen those drivers, I'll try them. I have no noise, however, and my sound quality is on par with using the optical out on my Audigy. I wonder if your noise was related to grounding? If you're not using an optical converter, the coax cable could introduce some noise into the sound.
The article doesn't mention that VIA's audio drivers also allow S/PDIF and analog to be sent out simultaneously, so I don't see that as an advantage. But his comments on resampling are interesting, although I can't compare since I don't upmix my 16 bit sources to 48KHz.
In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
Tested it this afternoon...Originally Posted by Vicne
SPDIF sound quality of the Realtek driver is excellent. Highly recommended. Thanks Vicne!
Software: RR, MM/FD
does it bring any improvements/feature enhancements even for analogue output?
Bunches of DSP features and equalizer presets, as well as a choice of different room acoustics (jazz club, theatre, sewer pipe), pseudo-3D etc.Originally Posted by LagunaICE
I haven't tested extensively yet, as the only SPDIF input is the one in my car, but at least my mp3s now sound like they should.
We should sticky Vicne![]()
Software: RR, MM/FD
'99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
MII12000opus120~MII12000opus120~MII10000opus150
NA~Senao dual 7.4 ant~Orinoco Gold
Pioneer~Pioneer~PG Octane-R R5.1MT
Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
Does anybody remember what driver this was talking about because the link doesn't work anymore?
Here's my setup, check it out.
http://www.mp3car.com/vbulletin/show...997#post934997
