Results 1 to 7 of 7
Thread: Chrysler 300 -- need aftermarket headunit?
    Dec 2005
    I am using a Chrysler 300 and I am researching in-car PCs. I am a little confused with how I go about hooking up the audio from the computer to the existing speakers. I am not looking at upgrading any factory audio if possible.
    So my question is, can I use my existing head unit? If so, how would I go about hooking up my computer to the factory kit? If not possible and if I need an aftermarket headunit, do I just have the wiring from computer out ==> headunit in ==> speakers?
    Thank you for your help.
    Dec 2005
    bump
    Newbie jaak's Avatar
    Mar 2004
    Toronto
    Which year 300? There is a way to mute the radio and depending on the year, you may be able to get a device to emulate an external changer.
    www.peripheralelectronics.com
    If it's a newer 300 it's a bit tougher.
    FLAC jbors's Avatar
    Nov 2003
    I think Car2PC-CHR will be available in Mar-06. So, look for beta testing annoucements.
    If you can't wait, just use AUX adapters that are available already.
    Good luck.
    Car pc integration with ease
    Car mediacenter
    Dec 2005
    I am using a brand new 2005 Chrysler and need it to be retrofitted ASAP.
    Question--
    I see that one person can hook up an amplifier directly to a computer, and then wire the amp directly to the speakers. I understand this concept, a great alternative to my situation. And just for stupid clarification which I think I already know the answer -- if I were to do that, would the stock head unit be out of service until the speakers are wired back up to the factory HU?
    I am going to custom build a touch screen monitor into the arm rest of the 300 with some sort of protection barrier above it, so when the driver/passenger puts arm on the arm rest, it will not interfere with operation.
    Sounds good so far?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by mikemccoy
    Question--
    Sounds good so far?
    You can get an aftermarket headunit, with aux in that will do this for you.
    Also, how do you expect to use the touchscreen if you have something over it to protect it??
    Michael
    Dec 2005
    Quote Originally Posted by Wiredwrx
    Michael
    The whole point is to NOT need an aftermarket headunit. If that means not using it, then fine. We are going to have a sliding plexiglass cover over it, so obviously when the driver wants to use the touch screen, slide off, use, slide back on. Get it? =) We might use a spring-type of plexi-setup, not sure what route yet. Going to run cables through the inside of arm rest, down, to back of trunk where comptuer is located.
  1. @005 Chrysler 300
    By MGD in forum Show off your project
    Last Post: 12-10-2005, 09:20 AM
  2. My Chrysler 300 Install
    By rb_selectblend in forum Fabrication
    Last Post: 08-11-2005, 06:43 PM
  3. Replies: 0
    Last Post: 03-15-2005, 12:49 AM
  4. aftermarket headunit with RDS?
    By stevewm in forum Car Audio
    Last Post: 06-27-2004, 12:08 PM
  5. Chrysler RBQ headunit
    By BucksCabin in forum Car Audio
    Last Post: 06-17-2004, 09:18 AM
