1) engine off, no whine, sounds AWESOME, even with the cheapo factory speakers.
2) engine on, whine present, remove RCAs in to amp and no more whine (this means the amp and speakers have no loop, anyway)
-incorrect assumption. You need to use grounding plugs (RCAs where the inner and outer cables are shorted) plugged in to test if amplifier is causing noise
3) plug in RCAs, whine present again. NOTE: changing cables (I have Monster cables 3.5mm to RCA) doesn’t help. When plugging in, if only 1 cable (pair of RCAs) feeding any two channels is present, I hear a LOUD hum in amp….
sound drops to the standard high-pitched whine when 2nd RCA pair is plugged in. Is this evidence of the ground being worse until the 2nd pair permits additional flow THROUGH the amplifier? Dunno, I’m EE challenged…)
-unsure on the one vs two plugged in, my guess is it is cutting the differential by 2 when you plug in both lowering the given noise compaed to all on one. Not surprised by this though.
4) All RCA ends plugged in, I next remove the 3 3.5mm ends from the Audigy 2 – no whine. I plug them into 3 turned off mp3 players I have just for grins to see if it is some strange electrical ghost – STILL NO WHINE. Looks like it is the PC or USB adapter…. Plug it back in to USB adapter, whine returns….
5) Screw wire into outside of case of PC where it also screws into PSU and ground to car…..no improvement. Screw 2nd wire into chassis of PC and then to same ground as before – no improvement.
-Hmm, this fixed mine
6) Disconnect Audigy 2 NX from PC and disconnect
power from USB sound card as well. WHINE STILL PRESENT! As best as I can tell, this is a plastic case, and it is not making contact with anything metal that might be an alternative ground, so what the heck????
-my amplifeir does this as well when power is off on the PC. I get your whine... it goes away when the computer turns back on. Im sure it has to do with how the SB cards handle their output when there is no power. again, not surprised.
I don’t know what to do next, folks. I guess I could try ground loop isolators but I didn’t want to because a) I want to figure this out, b) I understand they can adversely affect sound quality, and c) I would have to buy THREE of them to cover the 3 RCAs used to drive my 6-channels.
-try them and asee if they adversely affect the sound. You may not notice
