Results 1 to 5 of 5
Thread: Enabling Epia's Onboard Digital Out...
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    I am relatively inexperienced when it comes to dealing with motherboards and pin connectors....so I appologize in advance for this question which is probably fairly trivial:
    The online guide for enabling the digital out on the via epia boards says the following..."Enable the RCA/SPDIF selection jumper J11 on your motherboard to connect pins 3 and 4" and it shows a picture (which I have posted below) of a "blue bit" that connects the two pins together. Did they mean to say "Enable the RCA / S/PDIF selection jumper J11 on your motherboard to BY CONNECTING pins 3 and 4"?
    I don't know if it is just me, but the wording of those instructions seems pretty horrible. Is it saying that in order to connect pins 3 and 4, you have to enable the jumper J11....or is jumper 11 the same thing as pins 3 and 4?
    That "blue bit"...i don't have one of those, is it supposed to come with my motherboard? Can I just buy one from a computer parts store like Fry's? Is there a wire comming out of it that connects elsewhere, or is its sole purpose to unite those two pins?
    I'm sorry for sounding like a newbie, but the instructions were not very clear to me...
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    Quote Originally Posted by 3onDubs
    Typical Taiwanese English...
    Jumper J11 consists of 4 pins, numbered 1 to 4.
    Connecting pins 3 and 4 (and leaving 1 and 2 open) will enable SPDIF.
    Connecting pins 1 and 2 (and leaving 3 and 4 open) will enable TV out.
    Hope this helps.
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
    Aug 2005
    Anaheim Hills, Ca
    Quote Originally Posted by mox
    Hope this helps.
    You solved all my problems...thanks bro...you should've wrote the manual
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    mox
    mox is offline
    Nov 2004
    The Netherlands
    Not sure if you will be using SPDIF, but check Sound quality of SPDIF output on EPIA boards on how to improve SPDIF output.
    Software: RR, MM/FD
    Aug 2005
    Anaheim Hills, Ca
    Thanks...I read that a couple days ago and told myself I was going to download that driver as soon as I got everything up and running (which I did yesterday finally)....great find
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  1. SDPIF digital Coax into car audio pieces
    By RedGTiVR6 in forum Car Audio
    Last Post: 10-14-2008, 01:06 AM
  2. For those who want true 5.1 Dolby Digital and DTS
    By antimatter in forum Car Audio
    Last Post: 06-29-2007, 12:54 PM
  3. 5.1 channel Sound cards with onboard toslink (not in the add on case)
    By psyclobe in forum General Hardware Discussion
    Last Post: 06-15-2006, 01:43 AM
  4. Digital to Analog Converter
    By Maukio in forum Car Audio
    Last Post: 02-01-2005, 12:58 AM
  5. XMDirect Digital Audio Output ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 09:10 PM
