Results 1 to 5 of 5
Thread: alpine cda 9811 aux in help
    Nov 2003
    Olympia, WA
    I bought the ai-net adapter that plugs into my cd changer port. Do I have to do anything else to get aux in functionality? I plugged in my video ipod to test it and I get no sound. I searched the forums and found that I may have to install an interrupt switch or something. Is that right? Anyone have instructions on it. I'm not very good at wiring so the more details the better. Thanks!
    Nov 2003
    Olympia, WA
    bump
    Constant Bitrate PitchBlack98's Avatar
    Feb 2005
    Littleton, CO
    Did you go into the settings on the headunit and turn on the Aux in setting. Give that a try and it should work without anything else
    The end of the Internet offically begins here...
    www.broke-off.com
    Nov 2003
    Olympia, WA
    I looked for the settings for enabling aux in but i couldn't find them. I don't have a manual because the stereo came with the care when I got it.
    Nov 2003
    Olympia, WA
    Solution!!!
    I figured it out! There's a switch on the underside of the deck. Flip the switch first. Next mute the deck and hit play on your iPod (my case) and it should work. I'm thinking it's going to work the same way for my carputer once I finish the install.
  1. Alpine AiNet aux input adapter SOLUTION!!!
    By aydensdad in forum General Hardware Discussion
    Last Post: 08-16-2011, 05:30 AM
  2. Alpine M-Bus Aux Input
    By MatrixPC in forum General Hardware Discussion
    Last Post: 07-05-2010, 11:17 AM
  3. Alpine CDM-7856: Can't activate AUX input!
    By Bogeyman in forum Car Audio
    Last Post: 06-21-2006, 08:37 PM
  4. Adding Aux to my Alpine head unit
    By dcstimm in forum General Hardware Discussion
    Last Post: 06-25-2005, 09:07 PM
  5. Replies: 13
    Last Post: 03-01-2005, 02:54 AM
