Results 1 to 2 of 2
Thread: kicker L5, 3 amps, HELP
    Dec 2005
    alright, i have a dual voice coil kicker L5, both 4 ohm, and i have 3 three 300 watt, 4 ohm amps, what would be the best way to wire this up without breaking anything, thanks for any help
    Maximum Bitrate Fusion-One's Avatar
    Dec 2002
    Montreal, Quebec
    Well, considering that sub is rated for 600w RMS, and assuming you have at least two of the amps which are identicle.. I'd say ditch that third amp, and just use two. One on each voice coil.
    Just make sure to take great care that you tune both amps so they're outputing the same signal power to each of the voice coils.
    This will give you the 600wrms the sub is rated for, and will keep your amps running cool at 4 ohms. Alternativly, if they're decent amps, you could parallel the sub to 2ohms running on One amp, and probably get about the same power as you would from both amps running.. this is the better option, imo.
  1. NEED A SOUNDS SYSTEM for cheap
    By BANSHEE 101 in forum Car Audio
    Last Post: 10-28-2005, 02:55 PM
  2. Replies: 13
    Last Post: 04-15-2005, 03:55 PM
  3. New Kicker Solbaric 10" L5 DVC Sub
    By brrman in forum Classified Archive
    Last Post: 01-15-2004, 04:10 PM
  4. Need help to choose amps and subs
    By carabuser in forum Off Topic
    Last Post: 09-28-2003, 03:56 PM
