Results 1 to 3 of 3
Thread: Sound Card with S/PDIF
    Low Bitrate unixxx's Avatar
    Sep 2005
    CA, USA
    Question Sound Card with S/PDIF
    Does it really matter what sound card I use for the S/PDIF output on my CarPC. All of the decoding will be done in a DSP, so does the soundcard just embed the AC3 in the S/PDIF? I'm looking at this cheap sound card which supports 24-bit 96KHz and 7.1 all in a low profile card:
    http://www.newegg.com/product/produc...82E16829117108
    Do the bit-rate and sample-rate of the sound card even matter if the card isn't decoding anything? Sorry if these are basic, it just doesn't seem like the card would have to do much if all of the decoding work is given to the DSP via a straight digital link. Thanks.
    # cd /home/fuzzymuzzle.com
    Intel Pentium M Dothan 750 1.8GHz 533MHz 2MB
    iBase MB896F w/ Intel 915GM
    [■■■■■■■■■■■■■■■■■■■■] 50% Done
    (Writing Front/Back End, Designing Electronics, and Completing Install)
    _
    Mar 2004
    Little Elm, Texas
    I could be completely off my rocker here, but I don't believe that there is that much of an importance in the card in this instance. Like in my car, I'm running optic out of the SB PCMCIA card into the alpine processor. The alpine is doing all of the processing. I have all eqs, etc. set at flat on the computer (disabled if possible).
    If someone else knows differently, won't they please speak up!?
    Jan Bennett
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Virginia
    I don't think it matters either, although I would go for a card that had good driver support. If that one hasn't had an update in a year, choose something else.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
  1. Sound card issues
    By gboy in forum Newbie
    Last Post: 02-25-2005, 10:38 AM
  2. sound card on home computer....
    By RedGTiVR6 in forum General MP3Car Discussion
    Last Post: 02-24-2005, 10:00 PM
  3. Sound card / noise
    By Tha Hombre in forum General Hardware Discussion
    Last Post: 05-16-2004, 12:01 AM
  4. How to hook it all up/How many watts?/What sound card to buy?
    By Seabass in forum General Hardware Discussion
    Last Post: 03-22-2004, 11:28 PM
  5. Any opinions on the Phillips Aurillium external sound card?
    By UMM in forum General Hardware Discussion
    Last Post: 02-27-2004, 04:39 PM
