Results 1 to 2 of 2
Thread: Vented Box
    Jul 2005
    Vented Box
    Hi, I've been trying to design a vented box since about one month but I'm not sure how can I do that, I,m using WinISD, and reading thread about who to desing the box but everything seem so confusing in my mind, I would like to know if someone can help me with it, I'm using two infinity 1032 Woofers. I want them in seperate chamber with a 2 port comming in the center of the box (between the two seats), Box would be 38inch wide, 16 in deep and maximum 13 inch high. I would like to use slot ports about 2 inch wide each
    Here are the spect for the woofer:
    Driver : Infinity Reference 1032W
    Vas : 1,264
    Qts : 0,40
    Fs : 30,70
    SPL : 91,00
    What is the woofer displacement ?
    _
    Mar 2004
    Little Elm, Texas
    http://www.carstereo.com/help/Articles.cfm
    hope that helps
    there's quite a few options there that you can research through for better specifications.
    Jan Bennett
  1. F/S: JL 12w7 Subwoofer with box!!! Pictures inside
    By neema12 in forum Classified Archive
    Last Post: 08-29-2005, 09:45 PM
  2. Wanting help with an ABC sub box
    By FyreDaug in forum Car Audio
    Last Post: 07-15-2005, 05:10 AM
  3. Box Loudness.... Help?
    By Harlanc03 in forum Car Audio
    Last Post: 06-08-2005, 11:10 PM
  4. Case design for a stowage box.
    By nibix in forum Fabrication
    Last Post: 07-10-2004, 06:12 PM
  5. M10000n Box
    By mikeyg35 in forum General Hardware Discussion
    Last Post: 04-05-2004, 11:22 PM
