Results 1 to 7 of 7
Thread: Huuuge favour needed from members from USA
    Jul 2005
    Wales, UK
    Hi everyone!
    I have a UK BMW E46. I'm looking to get a Peripheral Electronics SVEN4 so that I can remove the stock HU. Two Qs:
    1. Will I need a wiring harness (Scosche etc) to connect to the SVEN4?
    2. Will I also need the antenna cable convertor if I want to be able to plug it into a radio card?
    I've had no luck getting a store to supply or even post from the USA, a Peripheral Electronics SVEN4 and BMW wiring harness (is Scosche wiring harness the best?) and the antenna convertor (do I need this?). I need someone in the US to buy these items for me and psot them to me in the UK.
    This is the list from www.cardomain.com that I think I need:
    - Peripheral Super VEN 4 OEM Interface Adapter 4-Channel Aftermarket Amplifier / Receiver to Factory Premium / JBL / Mach / Bose System • Universal Signal Adapter Part #: PERSVEN4 $32.95
    - Scosche BW01 Car Stereo Wiring Harness 1990-UP BMW Part #: SCOBW01B $7.95
    - Scosche VWA Antenna Adapter 1980-UP VW / BMW / Ford Focus / Mercury Cougar Part #: SCOVWAB $5.95
    Subtotal $46.85
    Does this sound right?
    I will pay for the goods, delivery, re-delivery to the UK, P+P and of course extra for the trouble. Is there anyone who would do me such a favour? I can pay via PayPal.
    Thank you very much all! I much appreciate the help in advance!
    Cheers!
    LLOYDY
    Low Bitrate cabj21's Avatar
    Sep 2005
    New York
    I could help you, i got no idea on the parts you needed because i don't have a bmw but if you make sure that the parts are correct for your car i'll buy it and ship them to you...
    Jul 2005
    Wales, UK
    Thank you very much! As soon as I can confirm these are the correct parts I will let you know.
    LLOYDY
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    I have an e46, but I'm not using the factory amp so I didn't have to get the SVEN4. However, I've come across countless threads on http://forum.e46fanatics.com that discuss this. Go into the Mobile Electronics Forum and search for either carputer or SVEN4 and I think you will find what you need...if not, the sticky at the top of that forum describes a step-by-step detailed install of an aftermarket amp using the stock headunit. This is slightly different than what you are attempting, but he uses the SVEN4 peripheral I believe....this could also give you some ideas. Good luck...
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Jul 2005
    Wales, UK
    Thank you for the info. I will check this out now.
    LLOYDY
    Maximum Bitrate srcstc's Avatar
    Dec 2003
    New Jersey
    That's the wrong antenna adapter for your car. 2002+ models use a different antenna connector. You need this one http://www.scosche.com/scosche_carau...2&ItemID=VWA3B
    -Rich
    Dec 2003
    New Jersey
