Results 1 to 9 of 9
Thread: Center channel speakers?
    May 2005
    PNW
    Hey!
    I'm starting to do some research on the few available center channel car speaker models, and I was wondering if any of you have tried any? Just curious to hear some reviews on different ones. Thanks!
    -Ben
    Falls Church, VA
    Why does it have to be a special speaker for center channel? They make cruddy ones that fit behind the rear view mirror and even in a din slot, but do you want so much of your 5.1 coming from overpriced laptop speakers?
    The "perfect design" is to have all 5 speakers identical with idential powering. This can be challenging dependent on the vehicle. Most of us have to mix and match.
    In my case, I have a pair of MBQuart 6.5" coaxs from back in the day. One of the pair is blown. Looks like i have a great center channel speaker! The trick is fabricating the right enclosure.
    Feb 2005
    New Jersey
    I had the clarion 1/2 din size center speaker. The SQ was ok.
    _
    Mar 2004
    Little Elm, Texas
    1/2 din speaker!!!
    WTF?!?!?!
    do you have a link to that little puppy!?
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by 3Tripnip
    Hey!
    -Ben
    I seem to remember there being quite a few posts about this topic - try searching for center channel or center speaker, etc in this forum...should come up with a few good threads...
    or there's always the phantom center...
    Jan Bennett
    Feb 2005
    New Jersey
    Quote Originally Posted by Red GTi VR6
    1/2 din speaker!!!
    WTF?!?!?!
    Clarion SRK5
    _
    Mar 2004
    Little Elm, Texas
    interesting to say the least...I'd really wonder what the SQ was like outta that thing...
    then again, it is a Clarion...
    Jan Bennett
    Variable Bitrate we87's Avatar
    Nov 2005
    Dallas, TX
    ...or there's always the phantom center...
    So it is possible to have two front, two rear, and then just "phantom" your center channel by letting it come out both front speakers, connect on that to a 4 channel amp, and have a 5.1 setup?
    Just asking to make sure....
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Virginia
    It's still a 4.1 setup, not true 5.1.
    Mixing the center to front left and right is the best way to do it IMO.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
  1. Replies: 11
    Last Post: 06-27-2005, 10:21 AM
  2. Lilliput speaker as center channel?
    By ummagawd in forum Car Audio
    Last Post: 04-14-2005, 12:46 PM
  3. good question about center channel speakers
    By mengela in forum General Hardware Discussion
    Last Post: 10-04-2004, 05:13 AM
  4. Replies: 8
    Last Post: 09-01-2004, 02:54 PM
  5. WRX owners. Clock or Boost Pod Gauge area. Center channel Speaker.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 04-02-2004, 05:37 PM
