Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
Thread: PCI to amplifiers?
  1. #21
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    not in the uk!
    terrestrial digital seems best (like dvd), then cable, then sky.
    Lez, more widely known as flez1966
  2. #22
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by lez
    not in the uk!
    Yes, in the uk. My UK PC kicks out a digital picture (DVI). It is superior to analog (VGA). The console devkit sat on my desk at work kicks out a digital picture (HDMI). It is superior to analog (scart).
    I feel you have compression mixed up witgh digital. Digital does not necessarily imply compression.
  3. #23
    Apr 2006
    Best Sound Card
    I am a true fan of Creative Labs.
    I am using a 2.2ghz toshiba laptop for my carputer.
    I will be using no HU, so audio card will provide sounds for movies, music and mic input will be used as the bluetooth phone.
    My first question is:
    How noticable is the difference between Audigy and X-fi?
    I could get something like MAGMA's 1 Slot CardBus to PCI Expansion System to connect PCI to laptop. Is it worth it?
    Otherwize what are PROS/CONS to using either:
    AUDIGY 2 NX
    or
    AUDIGY 2 ZX Notebook
    Thanks a lot for your help,
    t.
  4. #24
    Apr 2006
    Or maybe even go with Creative LIVE 5.1? I have had one in my pc for last 6 years and it works great, that would be a bargain.
    Let me know,
    t.
  5. #25
    _
    Mar 2004
    Little Elm, Texas
    I would first want to know what the quality of your stereo components are before worrying too much about the quality of your sound card.
    Jan Bennett
  6. #26
    Apr 2006
    I havent bought them yet, I was looking into midgrade (exploid?).
    What is the best value system out there?
    t.
  7. #27
    Falls Church, VA
    make a new thread...
    and explode is low grade
  8. #28
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    if you guys do some research on the cheapy sb live 5.1 card paired with the kxproject drivers you'll find that a lot of people find that card hard to beat for the price.
    as far as the picture quality comment. I invite you to come down to where i work and tell me that our final images are better or worse then analog. You can't tell a difference of a 4k digital frame unless you are projecting it on an imax sized screen. Then you just bump up the renders to 8k and problem is solved. plus...99% of the moving analog images that you do see have gone through some digital processing. Also Analog film isn't as true to reality as digital, but it's what we have been conditioned to think looks right. I'm not saying that i like the look of digital better, but you can't say outright that analog is better.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  9. #29
    Newbie ashmk1's Avatar
    Mar 2006
    Wales
    next I'l be getting told that the picture quality of digital is better than analog.
    I like the cmedia chipset, it seemed best of all the budget cards, but also the 'front end' bolted on afterwards makes a difference, its only a few resistors and caps but can make or break the curve.
    I cant hear that much difference, but can hear upto 21k, and yes tv's do drive me nuts if the windings are loose.
    I /know/ vinly sounds better than audio, I can hear it, I know analog TV transmissions (in good signal strength areas) are better to look at than digital, but problem now is all the editing/mastering and feeds to the TX towers are digital.
    But as for the soundcard issue, I tried the cheapys and the mid range and found nothing to shout about between them.
    maybe if I tried a 100+ card I would hear it, or think I could, because it cost 100+
    the armchair is for serious listning and its gota be vynil on a gyrodeck
    Not done much but its a start :
    http://uk.geocities.com/ashtp@btopen...m/MySpace.html
    Free to take a peek :
    @sh :
  10. #30
    Mar 2006
    Wales
    Quote Originally Posted by Rob Withey
    Happy to oblige.
    only in still frame
    @sh :
  1. FS: M10000 Dual PCI Card & Flexible PCI ribbon riser
    By Bugbyte in forum Classified Archive
    Last Post: 09-26-2005, 09:15 PM
  2. M10000 and PCI riser (or cable)
    By TucsonPred in forum General Hardware Discussion
    Last Post: 06-30-2005, 10:06 AM
  3. FS on eBay: selection of PCI and AGP risers
    By lemming in forum Classified Archive
    Last Post: 04-10-2005, 07:58 AM
  4. pcmcia pci or pci card?
    By fuctup in forum Wireless Communications
    Last Post: 11-14-2004, 02:49 PM
  5. PCI Graphics or Sound card - EPIA M10000
    By ZimZimmer in forum Newbie
    Last Post: 08-05-2004, 10:02 PM
