Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Static when using power mirrors!
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Angry Static when using power mirrors!
    Ok so I just finished the AUX-in MOD for my OEM HU, everything works perfect (no ground loops etc) but today I when for a test driven and I found that there is static in the radio (FM, AM , CD player, new AUX-in) when using the power mirrors! also I just noticed that if I remove the fuse label "mirror" on the fuse block, the radio lose power (even when having a separate fuse label "audio")
    I really need help on this one cus I don't know what to do.
    Thanks in adavance for any good tip.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Low Bitrate mbayers's Avatar
    Aug 2005
    Pasadena, CA
    Quote Originally Posted by thanatos106
    ... I found that there is static in the radio (FM, AM , CD player, new AUX-in) when using the power mirrors!
    Thanatos.
    Doctor, doctor! It hurts when I do this!
    Do you play with the mirrors that often?
    MBA
    2000 Ford Explorer Eddie Bauer
    CarPC Status: As of 03 Jan., 2006 - installed & running!
    Epia MII-10000
    512 MB RAM
    Lilliput 7" LCD
    Toshiba 40GB HDD
    Panasonic Slim slot-loading DVD
    Holux GPS w/ iGuidance
    XM PCR
    RoadRunner
    Nov 2004
    Well if I'm going to do something I have to do it right, and to answer your question I'm no the only one driving my car so what you will do if you have a $1000+ pice of HW in your car and as soon as you use something else, it going to start making noises and ****?
    Thanatos.
    Nissan Aux-in MOD
    Aug 2005
    Pasadena, CA
    Thanatos.
    No intention to annoy or anything. Your post just reminded me of the (very) old joke where the guy says, "Doctor, it hurts when I do this." and the doctor responds "Well, don't do that!".
    Apologies for any irritation caused by my post.
    MBA
    Epia MII-10000
    512 MB RAM
    Lilliput 7" LCD
    Toshiba 40GB HDD
    XM PCR
    RoadRunner
    Nov 2004
    So nobody can give me some advice about this?
    Thanatos.
    Nissan Aux-in MOD
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Wow, 3 1/2 hours and you think no-one can help you...!
    What I would do is:
    1) Fix the wiring so it's wired to the correct fuse.
    2) Insert a noise supressor/choke to the radio power line.
    Nov 2004
    What do you mean to fixing the wiring? if I remove the "audio" fuse there is no power to the radio, same if I remove the "mirror" fuse, or are you talking about get a diferent power surce fo the power mirrors?
    Also can you recommend a good noise supressor... thanks.
    Thanatos.
    Nissan Aux-in MOD
    Nov 2004
    Quote Originally Posted by Rob Withey
    What I would do is:
    That is nice editing skills.
    Also I didn't said nobody can help me, I was making a litle bump
    Thanatos.
    Nissan Aux-in MOD
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    You need a noise supressor for the power source. between the radio and the fuse block. You might also get away with a simple capacitor on the power line to absorb the noise. I used capacitors on my RC car electric motor, to kill any noise that the engine would give out. Maybe a couple 22pf caps on the motor to the mirrors. cap to + and - then to ground. I'm suprised you getting mirror noise and not engine noise. I always liked the sound of my engine winding up through the stereo
    Maybe im rambling, Goto radio shack and buy the $20 noise supressor.
    Question for you: have you tried to unplug the carputer from the aux in too see if the noise goes away? maybe you do have a ground loop from pc to stereo.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Why do you use the power mirrors? You just set it and forget it
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 06:31 AM
  2. Power supply Problem
    By xGROMx in forum Power Supplies
    Last Post: 03-16-2007, 01:19 PM
  3. Power inverter problem.
    By blackedoutxb in forum Power Supplies
    Last Post: 11-14-2005, 09:51 AM
  4. Replies: 7
    Last Post: 06-15-2004, 09:29 PM
  5. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 06:32 PM
