Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Amp Delay Turn On Solution?
  1. #11
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    I think a service/program like that already exists...
    Then you hook up a relay to the DTS (or something) pin of your serial port (maybe with a transistor).
    Sorry to be nowhere near precise but it does exist...somewhere...i think...lol
  2. #12
    Newbie thenick100's Avatar
    Jan 2006
    lol yeah i found a link for it on another post from last year but it was dead! i have a transistor and diode circuit already built for something else which i can use, just need the program!
  3. #13
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    What about using something like this to sense when there's voltage/signal/sound coming out of the sound card, and having it turn on the amp at that time?
  4. #14
    Jan 2006
    nah cos surely then it would come on when the pop happened?
  5. #15
    Admin
    Aug 2005
    Forget a timer chip. If you've got a parallel port, here is everything you need to know to use to turn your amps on and off:
    http://www.epanorama.net/circuits/parallel_output.html
    If you don't have a parallel port, you can also use the DSR/DTR lines of a serial port, but I couldn't find a sample page in less than 30 seconds so you're going to find that on on your own...
    -g.
  1. Replies: 97
    Last Post: 03-10-2013, 06:28 PM
  2. David Navone Amp Turn on delay (pop eliminator)
    By Kamakazie2 in forum The Review Palace
    Last Post: 01-08-2007, 08:29 PM
  3. Amp Popping on power down
    By tjp12100 in forum Newbie
    Last Post: 12-26-2005, 11:22 AM
  4. AMP wont turn ON!! HEELP!
    By pdjafari in forum Car Audio
    Last Post: 10-15-2005, 08:43 PM
  5. Having problem with AMP, need HELP!!
    By ryuandwings in forum Car Audio
    Last Post: 05-01-2004, 08:31 PM
