Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
Thread: Some advice on amp for subs
    Low Bitrate LowLux's Avatar
    Oct 2005
    Qld, Australia
    Hey just bought two new 12" Alpine Type R, and they are rated at 500W RMS, and i was looking for an amp today to handle them.
    Would two of these do?:
    KENWOOD KAC-9102D 1700 WATT MONO AMPLIFIER
    # Amplifier Type: Mono
    # RMS Power: 500W x 1 @ 4 ohms
    # THD at 4-Ohm RMS Power: 0.08 %
    # RMS Power: 850W x 1 @ 2 ohms
    # Speaker Level Inputs: Yes
    # Preamp Outputs: Yes
    # Built-In Crossovers: LP
    # Bass Boost: 0 - 18 dB
    # Frequency Response: 5-200 Hz
    # Signal to Noise Ratio: 100 dB
    # Fuse Rating: n/a
    Cheers guys...
    Falls Church, VA
    Why 2? Why not just run one? Yes, two would produce more power than one (about 15%) but is it worth 2x the cost and current draw?
    Keep in mind that since the 2 speakers can handle 1000 watts, and the amplifier produces 850 at 2 ohms, does not mean that the speakers can handle whatever you toss at them. You still have to pay attention to distortion.
    Also, that power rating is probably for a sealed enclousre with 1.25 cu/ft per speaker. That number lowers when you use a ported or bandpass enclosure
    _
    Mar 2004
    Little Elm, Texas
    Type R subs deserve better
    Jan Bennett
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    (read as what she said)
    Oct 2005
    Qld, Australia
    Quote Originally Posted by Red GTi VR6
    What would you suggest mate? Well i love my base and thats why i bought two...
    Also i don't want to waste these subs in a universal box, should i make one up or will any car store be able to do a better job?
    thanks
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by LowLux
    thanks
    http://cgi.ebay.com/Brand-New-in-Box...QQcmdZViewItem
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    _
    Mar 2004
    Little Elm, Texas
    I would suggest something a little more high end than a Kenwood
    JL AUdio
    Alpine V12 (2 of these would kick ***: http://www.alpine-usa.com/en/product...model=MRD-M605 or if money is an issue: http://www.alpine-usa.com/en/product...model=MRP-M650 two of those)
    The PG would work
    I have just never been a big fan of Kenwood...they make OK product, but that's about it IMO, nothing great.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    if you can swing it: http://www.alpine-usa.com/en/product...odel=MRD-M1005
    would probably work, but I understand it's "expensive" to some budgets
    just don't skimp on the amp, whatever you do, don't skimp on it!
    Jan Bennett
    Oct 2005
    Qld, Australia
    Hey, would you consider these kenwoods skimping?
    the amp you suggested second only puts out 400W x 4ohms (0.08 THD) and 600W x 2ohms.
    the kenwoods are 500W x 4ohms (0.08 THD) and 800W x 2ohms?
    Sorry i don't understand this, are you just going by the quality of the brand, because i got the impression more RMS Watts to the sub = Better.
    I was looking at buying one Alpine V12 and running them both from that, but im sure the 2 kenwoods would be better?
    Cost is a thing for me, i didn't want to cap $2500AU when setting up my system:
    Already bought:
    Sony Xplode Headunit: $370
    Kicker 6x9" Speakers: $100
    2 x Alpine R Type 12" Subwoofers: $565
    Still Need:
    Kicker 6" Speakers: $115
    2 x Approx. 500W RMS Amps: $700
    Touchsreen 8" Moniter: $350
    Wiring & Installation: $300
    Sub Boxes: $150
    thanks guys...
    Oct 2005
    Qld, Australia
    Sorry, would this Kenwood be better than the one i first suggested, i would have to bridge both of them, but its cheaper and says it would output 500W @ 4ohms the same as the first one...
    KENWOOD KAC-7252 1000 WATT 2-CH AMPLIFIER:
    # Amplifier Type: 2-channel
    # RMS Power @ 4 Ohms: 170W x 2 @ 14.4V
    # Bridged RMS Power @ 4 Ohms: 500W x 1 @ 14.4V
    # Built-In Crossovers: HP/LP
    # Frequency Response: 10-45,000 Hz
    # Fuse Rating: n/a
  1. vw mk4 monson amp and another amp
    By colorless in forum Car Audio
    Last Post: 09-05-2012, 11:43 AM
  2. del
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  3. Replies: 2
    Last Post: 08-22-2005, 05:37 PM
  4. Help hooking up subs and amp? Need advice...
    By jedi7001 in forum Car Audio
    Last Post: 05-17-2005, 02:28 AM
  5. advice on amp
    By KingRudy in forum General Hardware Discussion
    Last Post: 06-16-2004, 12:52 AM
