Results 1 to 9 of 9
Thread: Inline Fuse Holder Question
    Cleveland, OH
    I am going to be installing a new audio system to tie into my carputer and I was wonder if you attach the inline fuse holder to something. I have seen installs that do not attach the inline fuse holder to anything in the car and it just dangles. I have also been highly warned to screw securely into the firewall or some other place.
    I was thinknig about screwing into something very near the terminal but far away from engine using rubber washers to cushion. Any suggestions?
    Aug 2005
    Near Buffalo, NY
    Ive just zip tied it to something strong near by it. That has always worked for me. Just because the placement has been inconvient.
    Constant Bitrate doublet's Avatar
    Aug 2005
    OKC, Oklahoma
    Cleveland, OH
    Wow, I have been warned and yelled at to screw it into someplace like the firewall to keep it safe. Hmmm, ok.
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by dbzeag
    What kind of inline holder? A blade or one of those ones that turn and lock?
    Cleveland, OH
    Quote Originally Posted by shotgunefx
    http://knukonceptz.com/productDetail.cfm?prodID=FH-20
    turn and lock
    Apr 2005
    Boston, MA
    I guess the concern would be what happens if it pops open? Can a piece of the end connected to the battery ground?
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    Yelled at? Who's yelling at you...make em stop...tell them you don't like it when people yell
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    _
    Mar 2004
    Little Elm, Texas
    Not attaching the fuse holder to something is one of (if not THE) biggest pet peeve of mine. It shows a lack of skills and someone who is just willing to 'settle' and doesn't spend the few minutes to relocate it to an appropriate place. I'll put it this way, if you were to take that install to a competition, chances are you would be laughed at...all the way out of the door, then talked about later... I can't STAND ghetto stuff like that, it's horrific...
    Don't worry about cushining this fuse holder. If it's made for the car, it will work perfectly fine in the car environment, absolutely no need to shock mount it.
    As for using screws, ABSOLUTELY, HANDS DOWN, NO DOUBT ABOUT IT. Self tapping metal screws work the best. If you can't find a place to mount it MAKE A PLACE. BTW - 18 wire inches from the center of the positive battery terminal to the output of the fuse....that's the accepted standard distance and anything more gets points counted off in competition. It's also the accepted standard in MECP terms. (I believe it's even a question on the MECP exam....but I could be wrong)
    BTW - zip ties don't count for JACK either
    Jan Bennett
  1. ANL fuse install
    By UM_Fan in forum General MP3Car Discussion
    Last Post: 11-26-2005, 09:06 AM
  2. What fuse to use?
    By Meelobee in forum General Hardware Discussion
    Last Post: 10-07-2005, 05:13 PM
  3. Adding another fuse??
    By Cheekz185 in forum Car Audio
    Last Post: 10-01-2005, 11:03 AM
  4. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 05:59 PM
  5. Fuse Question
    By ToesToes in forum General Hardware Discussion
    Last Post: 08-04-2000, 09:11 AM
