Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Dumb question about amplifiers
  1. #11
    Nov 2005
    UK
    Why don't you run the HU through the PC (link it to a line-in on the sound card) if you are not using its internal amp.
  2. #12
    Constant Bitrate RawsonDR's Avatar
    Dec 2005
    Dayton, OH
    Quote Originally Posted by DavC
    If he has no amp, then the headunit must be doing it. The RCA jacks, though, could go into the computer assuming he wanted them available for mp3 players and other line level audio sources. Whether or not noise is introduced, I dunno.
  3. #13
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    Stock HU adapter.
    Quote Originally Posted by hd1080
    Thanks for the input guys; this has been helpful. Unfortunately my car stereo does not have an AUX input. :-/
    Is it a stock HU ?
    You can get an adapter for a lot of different stock HUs that pretend to be a cd changer. This would allow you to use your HU as an amp and retain fade/balance control.
    Check Crutchfield.
  4. #14
    Jan 2006
    It is a stock HU and this does seem like the ideal solution. There is such an adapter at Crutchfield, but it seems to suggest that you need an AUX button on the radio. I'll look into this some more though.
  5. #15
    Jan 2006
    Oh man, these boxes look pricey... Is there a way to hack the wiring to send a signal straight to the HU?
    (I've got a 1997 Saturn SL2, by the way)
  6. #16
    Admin
    Aug 2005
    Mainly because it's just not as much fun. I want the challenge of building my own. Plus, with a car PC I can customize the interface, and there's room for expandability, like ODB-II if I ever go that route.
    In that case, you might want to consider something like a Dell Axim 51 which can be had for about $300 on sale (check slickdeals.net)
    -g.
  7. #17
    Jan 2006
    I don't quite see how that dell can amplify my signal...
    Anyway, here's my idea, and I don't know how well this works out electronically so I'll run it by you guys. If I knew how to do a wiring diagram I would. Sorry. I'm going to use an old HU with an aux input as the amp for my PC. Where this gets power, I'm not sure... Can I run it in series off the power of the main HU I have installed? Or is there a better way?
    Also, I want to be able to use both head units and have them both attached to the four speakers. Is it possible to use, say banana plug connectors (this is just the easiest way for me to describe what I want to do) in all the sources? So for the front left speaker, I would have the speaker accepting an input from the old HU, which accepts a signal from the main HU. I hope this makes sense. So the old HU (the one in the middle) would have a banana plug with both a male and female connector on it. Is this feasible? Is there an easier way to wire this without spending money on costly banana plug connectors?
  8. #18
    Constant Bitrate OoNikFraleyoO's Avatar
    Mar 2005
    Alabama
    Your best bet is a new HU with an AUX input. The 2 HUs thing isn't gonna work very well if at all. It's gonna be cheaper to just do it right the first time than to redo it afterward.
  1. Dumb noob question
    By TaZMaNiaK in forum FrodoPlayer
    Last Post: 04-02-2005, 01:52 AM
  2. Dumb USB DVD question
    By Sir Lancerlot in forum Newbie
    Last Post: 01-31-2005, 02:59 PM
  3. Dumb question, MP3 storage?
    By judoGTI in forum FrodoPlayer
    Last Post: 07-04-2004, 10:37 AM
  4. dumb question!!
    By cooljavy in forum Power Supplies
    Last Post: 05-26-2003, 12:35 AM
  5. dumb question. how do you turn on the pc?
    By Heedunk in forum General MP3Car Discussion
    Last Post: 04-03-2001, 01:49 AM
