Results 1 to 10 of 18
Thread: Dumb question about amplifiers
    Jan 2006
    I'm in the planning stages of a car PC which will be used solely to play MP3's. I'm considering going from the line out of my sound card straight to the speaker inputs. I know this is a stupid question, but do I need an amplifier? If I do, what are some good ways to do this for cheap? Thanks.
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    I don't know if it is possible to do it without an amplifier, but I do know that it makes it a heck of a lot easier because you simply plug in the RCA's from the sound card into the amplifier. If you want a cheap amp, I have a couple for sale.....PM me if your interested.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Nov 2005
    UK
    Jan 2006
    Alright, so an amp is needed...
    Another question if people are up for it: I'd like to be able to select between 2 or 3 inputs for the speakers. One of these would be the stock car stereo. The other would be the PC, and the third (if possible) would be a pair of RCA jacks. I'd use the basic components of a selector from radio shack to do the job, but would it work to have the speaker out on the stereo go in as one input, the PC (followed by the amp) to another input, and then the RCA jacks to another? I'm guessing the RCA jacks are going to need an amp too, huh? Also, how could pan & front/back selectivity work? Maybe I need to think this through some more...
    Elsewhere
    Yeah, you do need to think this through a bit more.
    If you want to select between different audio inputs, you can get selector switches for that very purpose.
    If you have a headunit with AUX-in, why don't you just run the audio form the PC through the headunit? Then you don't need an amplifier. Seems like a more cost-effective way to go.
    You can still use the audio selector witht he oputput going into the headunit and the various audio sources as inputs to the selector.
    Then you select the AUX on your headunit and you'll get audio from whatever source you have selected.
    How about the Wiki?
    Aug 2005
    Anaheim Hills, Ca
    Quote Originally Posted by hd1080
    Why do you need 3 inputs? If you can stick with two inputs (head unit and pc), than you can use the aux in on your head unit to connect your pc audio. Then you can run one set of RCA's from your head unit to your amplifier. If your head unit is a stock car head unit, than it might not have the aux in location on the back of it. In that case, I would suggest either ditching the head unit completely, or upgrading to an aftermarket head unit that has aux in terminals.
    You do not want to use an audio selector before your amplifier. This will introduce noise into your system and is definitely overkill. As far as the fade/balance settings goes...if you have a four channel amplifer, than you will dedicate one channel to each of your 4 car speakers. Then you can still use your head unit to control the fade and balance. If you go with a two channel amp, than you have to sacrifice either fade or balance. Most people would rather sacrifice the balance since you always want both sides playing evenly.
    Hope that helped a little.
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Aug 2005
    Anaheim Hills, Ca
    Quote Originally Posted by DarquePervert
    Good point....if you have aux in on your head unit, then you don't even need an amplifier
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Jan 2006
    Thanks for the input guys; this has been helpful. Unfortunately my car stereo does not have an AUX input. :-/ While it seems it would be easiest to buy one, I'm hesitant to, mostly because of cost. Plus that would void my reasoning to build a car PC. Although I suppose an amp would be up there in costs too...
    Admin
    Aug 2005
    Then why bother with the trouble and expense of a PC when an iPod will do the job just as well?
    If you want to be able to hear anything, yes.
    -g.
    Jan 2006
    Mainly because it's just not as much fun. I want the challenge of building my own. Plus, with a car PC I can customize the interface, and there's room for expandability, like ODB-II if I ever go that route.
    I did just remember that I have a very old but high end head unit with an aux input. I'll see if I can't tuck that in the back and use it as a makeshift amp for the PC... I don't want to use it as the main head unit because the interface is shot, but the electronics inside all seem to work decently.
  1. Dumb noob question
    By TaZMaNiaK in forum FrodoPlayer
    Last Post: 04-02-2005, 01:52 AM
  2. Dumb USB DVD question
    By Sir Lancerlot in forum Newbie
    Last Post: 01-31-2005, 02:59 PM
  3. Dumb question, MP3 storage?
    By judoGTI in forum FrodoPlayer
    Last Post: 07-04-2004, 10:37 AM
  4. dumb question!!
    By cooljavy in forum Power Supplies
    Last Post: 05-26-2003, 12:35 AM
  5. dumb question. how do you turn on the pc?
    By Heedunk in forum General MP3Car Discussion
    Last Post: 04-03-2001, 01:49 AM
