Results 1 to 10 of 16
Thread: Soundstream XTA720.4 VS. JL 300/4
    Maximum Bitrate 3onDubs's Avatar
    Aug 2005
    Anaheim Hills, Ca
    Which amp would better suit my speakers? I will be running the amp in 2 channel bridged mode because I have no rears. I am running 2 CDT EF-61 components. Here are the details for the components and amps...
    CDT EF-61
    6.5" 2-way
    Midrange: 6.5" Cast Carbon Treated Paper Cone
    Crossover: SatNet-400 Elliptic 4th/5th order 2-way
    Tweeter: TW-24 1" Smooth Silk Dome
    Power handling: 120 watt RMS
    Frequency response: 60-20kHz
    Sensitivity: 90.5 dB.
    Impedance: 4 Ohm
    Surface & swivel flush mount housings
    90 X 4 at 4 ohms Output RMS
    180 X 4 at 2 ohms RMS
    360 X 2 at 4 ohms RMS
    0.05% THD
    10 - 30k Hz Frequency Response
    96db Signal To Noise Ratio
    200 Damping Factor
    200mv Input Sensitvity
    12db Crosover Slopes
    30 - 500 HZ Crossover Frequency High-Pass
    30-150 Hz Low-Pass
    0 - 18db Subwoofer EQ
    Bi-Linear Selectable Crossovers For Inputs And Outputs
    Continuously Variable High And Low-Pass Crossovers
    Variable Subwoofer Equalizer
    Phase Inversion Switch (0 - 180º)
    Platinum 4-Gauge Power Connectors
    Tri-Mode Operation
    JL Audio 300/4
    Rated Power (4 Channel Mode): 75 W RMS x 4 @ 1.5 ohm-4 ohm (11V-14.5V)
    Rated Power (Bridged to 2 Channel): 150 W RMS x 2 @ 3 ohm-8 ohm (11V-14.5V)
    THD at Rated Power: <0.03% @ 4 ohm per ch.
    S/N Ratio: >108.5 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
    Frequency Response: 5 Hz - 30 kHz (+0, -1dB)
    Damping Factor: >200 @ 4 ohm per ch. / 50 Hz >100 @ 2 ohm per ch. / 50 Hz
    Slew Rate: ±25 V / µS @ 4 ohm per ch.
    Left to Right Channel Separation: >75 dB @ 1 kHz
    Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Low Bitrate keen70's Avatar
    Dec 2005
    IMO id use the JL
    Aug 2005
    Anaheim Hills, Ca
    I feel like an idiot...i just re-read the stats on the soundstream and I see that it puts out 360 X 2 @ 4 ohms. I have been bridging my channels and running my fronts off of this thinking that I was giving each speaker 180 watts. I reverted back to using it in 4 channel mode so that I can send 90 watts to each speaker.
    Does this sound right (the fact that it jumps from 90 to 360 when bridged)?
    How would I be able to get 180 watts to each speaker? The only way I can think of is to run both speakers off of one shared bridged channel. The only draw back to this would be that I would lose balance control (which I never use anyway). Is there an easier way?
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Newbie Chillboy's Avatar
    Jan 2006
    Sure it will run 360W but the amp is really seeing a 2ohm load so distortion is above .5% and prob just under an audible 1%.
    If you are using a 4ch amp and only want to run front speakers off it you should invest in an electronic xover and run 3-way active imo.
    You can get one really cheap off Ebay now since amps have built in xovers. I don't think that yours has the range or bandpass capability you need to do this so you would need an external one.
    IMO it will sound much better then running bridged into each side.
    EDIT you can always turn the gains down to where you need them.
    Aug 2005
    Anaheim Hills, Ca
    Quote Originally Posted by Chillboy
    I am using a Digital Sound Processor that feeds my amps. It has a built in electronic crossover so it would allow me to run an active setup. I was doing this originally, but I couldn't get the tuning down, so I just went back to using my passive crossovers for now.
    What do you mean by 3 way active? My components are only 2 way....Do you mean tweeters, midranges, and subs?
    I have read through many active vs. passive debates, and there have been arguments for both sides....is active potentially better than passive if tuned properly?
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Jan 2006
    Quote Originally Posted by 3onDubs
    It is debatable. I've had a couple 3way active systems but run an amp that like passives better now (tube amp). But I think in your case with wanting to max the power without over powering (or 2ohm loading only to turn the gains back down) combined the control you already have in your system that you should give it another try. It gives much more control over the system and you should set xover points eq flat first then tune to your liking.
    Yeah 3-way active = tweeters, mid(bass), sub. I guess you have another amp on the rears and one on the subs too.
    The easiest way to explain the benefits is do you want to amplify a full range signal and cut a bunch of sound out or do you want to amplify the specific range you want to the speaker. Also tweeters are very sensitive. You'll end up setting the gain way lower on those channels and get the same output to match your mids. A friend with an o-scope and rta would make things really easy but start with a flat eq or even better your noise generator to match the output to each type of speaker.
    Aug 2005
    Anaheim Hills, Ca
    I'm actually running two amps and no rear speakers. One for the fronts and one for the subs. I always figured that it would be a waste of power to only amplify a part of the signal...why not amplify the full signal (and let the passives do the work) and free up a couple channels on the amp? This would be helpful to those with a shortage of channels.
    I know that this deserves a different thread, but what are the benefits of a passive crossover over an active setup. I know that the passives are designed specifically for the speaker...what exactly do they do other than cut off frequencies at a specific slope?
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
    Jan 2006
    Basically electronic xovers can be tailored to your car (listening environment) better. There's something to be said for a companies matched passives but unless they are really high end and you see lots of caps and coils to get a steep slopping x-over point then the electronic will prob own it.
    If you amplify the range of 0-80Hz to your sub, doesn't that make more sense that you will get more output then if you aplified 0-22kHz and chopped out part of the signal? That's a pro for electronic xover but I don't want to weigh too heavy on that unless you compete in spl.
    I think I mentioned that the only reason I use passives in my car now is that it's tube amped. They like a passive (generally) and they aren't efficient amps to begin with so why bother (my stereo gets louder then I like it), great reason is $ for another tube too but you already have 4ch's to play with. But if you can put more power to the midbass then the tweeter you will get more precence (fuller sound) at lower volumes.
    You have all the equip to run a nice 3 way setup. I'd give it another try but flatten your eq and run the white noise to get balanced output before you play with the settings. Set your headunit about 5 notches under the max vol 1st too since you can't oscope it to see where it clips.
    I'll guess the passives are 12dB/oct and your headunit/processor has nice 24dB/oct xovers built in (check I'm guessing). That means that if your manual for the components says xover point is 5K hz then you could prob let them play down to 4K hz (just an ex.). Don't forget that each speaker may sound like crap on it's own, just listen for distortion to set the midbass then match the tweeter with white noise generator or music you know.
    If it's still too much to think about there's nothing wrong with putting it in and having a local shop rta tune it for an hour to get you going. Stereo is the easy part for me it's deciding on setup for carputer that makes me scratch my head.
    Give it a try. I think maybe you had the xover set wrong or something first time around. It should sound better. You should be able to tune it exactly the way you want it.
    Jan 2006
    Last tip that I can offer is that if you have a decent home stereo, use it to help train your ear before you start to tune. After a little while you forget what you are supposed to hear sometimes.
    And I am no expert just a hobbyist, that's kinda rusty with todays equip., but the tuning almost remains the same.
    Aug 2005
    Anaheim Hills, Ca
    You're right...active setups can definitely be tailored to your car better. I know that if I was more patient with tuning my setup or if I had an expert to help out, then I would have definitely been able to get my speakers to sound right.
    The sound processor that I am using is actually loaded with features. I think that the slope on the x-over goes down to 36db for a really sharp cut off. You've convinced me to give active a second chance....I think I'll run my amp amp in 4 channel mode and give two channels to the tweeters and ditch my passives. I'll probably set it up and take it to an audio shop to see what they can do with the tuning.
    The reason I was asking about the JL amp is because I just purchased the amp from another mp3 member and I was wondering how it compares to my current amp. I still havn't received it, but I would probably be running it in bridged 2 channel mode so that my speakers would get 150 watts each.
    I had a quick question about ohm calculations. The JL amp says that it outputs 150 watts in bridged mode for 3-8 ohms. If I were to run both midranges to the same bridged channel and then run both tweeters to the other bridged channel, would both channels see an 8 ohm load? If so, would all four drivers be getting 150 watts a piece?
    Thanks for all your input Chillboy....just out of curiousity, what kind of a set up are you running in your car? Head-unit or no headunit?
    PostCount++
    - SrCsTc's Bezel
    - Alpine W200/H701
    - ED Nine.2X
    - OZ Matrix Elites
    - ED Nine.1
    - Idmax 12's
  1. wtb: jl audio 300/4 amp
    By EsKALad in forum Classified Archive
    Last Post: 02-21-2006, 08:27 PM
  2. FS JL 300/4 barely used
    By utley3specv in forum Classified Archive
    Last Post: 02-01-2006, 08:19 PM
  3. F/S: JL 12w7 Subwoofer with box!!! Pictures inside
    By neema12 in forum Classified Archive
    Last Post: 08-29-2005, 09:45 PM
  4. FS: JL e1200 + JL 10w3v2
    By tdevil in forum Classified Archive
    Last Post: 05-23-2005, 01:53 AM
  5. What speakers where?
    By DingleBerry in forum General Hardware Discussion
    Last Post: 07-05-2002, 08:34 PM
