M2-atx?
or what m2 are you talking about?
if you're not talking about the m2 power supply, you should look into getting either it or a power supply that has the amp turnon delay built in (which the M2 does)
So I was thinking about this last night because this project has totally emcompassed my conscious and unconscious thought patterns continuously, I have 2 devices that need to use the ignition wire to determine when to start.
I have an amp in the trunk that needs a delay to start after the ignition line goes high.
I also have an M2 that needs to start, but without the delay.
What type of wiring and/or relays and devices would I need to power such a situation?
What should I use to split the ignition line to drive those two devices?
Thanks for your help!
M2-atx?
Jan Bennett
I am talking about the M2-ATX power supplyOriginally Posted by Red GTi VR6
ok - so then...it's already got an amp turn on delay built into it...IIRC
the M2 will turn on the computer only after it sees a regulated voltage coming in...
then it waits a but before it sends the turnon to the amps...thus the anti-thump technology
it's the same withthe M1-ATX in my car
no delay circuit wired into the car...it works like a charm
Jan Bennett
Wow, I am an idiot and just read the directions. That makes a lot of sense :-POriginally Posted by Red GTi VR6
Thanks!
np! it happens to the best of us!
good luck with it all!
Jan Bennett
