Results 11 to 20 of 22
Thread: Another stereo whining question
  1. #11
    _
    Mar 2004
    Little Elm, Texas
    that tells me that you are getting induced noise in your speaker wire
    you should check the runs....speaker wire shouldn't be running next to any electronics...that's if it's just a hum
    does it vary with the engine RPM at this point?
    Jan Bennett
  2. #12
    Falls Church, VA
    He has a built in amp. I have never seen speakers pick up enough interference to cause audible whine. That just requires too much amplification to hear. Somewhere he has a stock amplifier. I would disconnect the wires at the speakers and toss some new speaker wires over the seats. Test a direct connection.
    I'm betting my 50 cents that the installers never bypassed the stock amplifier!
  3. #13
    Constant Bitrate Legarcondemerde's Avatar
    Jul 2005
    The Biggest Little City
    Hmm...I definitely agree with Will, that would certainly cause some noise issues if the lazy bastards didn't bypass a factory amp. What kind of car do you have?
  4. #14
    _
    Mar 2004
    Little Elm, Texas
    if they didn't, I'd take it back and throw a fit!
    Jan Bennett
  5. #15
    Sep 2005
    I honestly don't think there is a built in amp. It's an 2005 elantra gt. I will look it up to see if it has a built in amp. Where would it be (usually)? The whining does go up with RPMs, and does not exist when the amp is disconnected. I will test a direct connection between the amp and the speakers later today.
  6. #16
    _
    Mar 2004
    Little Elm, Texas
    I'd see about a different amp then
    do you have a friend with one you can swap in for a few and check?
    Jan Bennett
  7. #17
    Dec 2005
    i had a ground noise problem as well wit my setup, which goes from my carputer's speaker out jack to an aux input device for my stock head unit. the humming sound would increase with the rpm's. i moved some wiring around(kept all the power wires on side of the car and all the speaker wires on another) and this helped a bit since the humming sound decreased dramatically. Eventually I forked up the $15 for a ground loop isolater from radio shack, which took away the humming sound all together. it was a good $15 investment.
  8. #18
    Sep 2005
    I think I will try a different amp, to see if that's the problem. Skadoo, read the whole thread next time please. I've said twice that I have ground loop isolators installed.
  9. #19
    Jul 2005
    While you have the amp out, get an ohmmetter and check the impedance of the speakers. If they all read about 4 ohms, then you definitely don't have a factory amp.
  10. #20
    Sep 2005
    Can I find an ohmmetter at radioshack? are they cheap?
  1. Hooking up amp question REM line
    By Jake in forum General Hardware Discussion
    Last Post: 02-09-2007, 03:19 PM
  2. Newbie question
    By jaydm in forum General Hardware Discussion
    Last Post: 10-21-2006, 11:07 AM
  3. little question ive pondered..
    By John Crowe in forum Newbie
    Last Post: 04-06-2005, 05:09 AM
  4. 5.1/7.1 surround question
    By gmcgann in forum Car Audio
    Last Post: 02-10-2005, 11:26 PM
  5. Replies: 3
    Last Post: 12-03-2004, 05:51 PM
