Thats going to happen with windows booting. Mine does that as well. You need a delayed turn on for your amplifiers to turn the amps on AFTER windows boots. Its a floating ground loop.
In regards to the noise continuing... You have an amp that is powering the rear speakers and the front is off of a head unit? In that case, again, you have a ground loop with the amplifier. Get a ground loop isolator or start doing some research on eliminating ground loops.
LinkBack URL
About LinkBacks
