Results 1 to 4 of 4
Thread: Best way to adjust Gain, Frequency, etc?
    Maximum Bitrate CJ8501's Avatar
    Jul 2004
    Orland Park, IL
    Well I want good sound quality with my newly installed sub and amp. I was messing around with the gain while the volume was down, sub was not connected at speaker output, and was trying to measure the voltage across the channel with a voltmeter but it was showing up? Also, shouldnt a sub get progressivly louder when the gain is being turned up? Mine didnt do a thing. It just stayed the same. Is there a problem with my amp or something? Any help would be greatly appreciated Thanks
    Mar 2005
    NY
    I was always told you mess with the gain at 2/3 to 3/4 volume. Maybe that's why you're getting no change? Could be wrong. What are the specs of the equipment you are using?
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
    Low Bitrate keen70's Avatar
    Dec 2005
    dont turn gains up to high, turn ur gains down 2 0 and then ur stereo up 75%, turn ur gains up till it distorts, then turn it down a little from that...theres uyr gain settings.
    _
    Mar 2004
    Little Elm, Texas
    you will need a sound track of 1000hz @ 0db to set gains...
    you will need to listen for clipping while ou adjust the gains, go from the gains being at 0 up. When you hear the frequency change (head unit volume will need to be turned up quite a bit at this point), back off and leave it there.
    Your gain will be set correctly if you do this correctly.
    Jan Bennett
  1. Active gain
    By Motoko in forum Centrafuse
    Last Post: 01-27-2006, 04:10 PM
  2. ALPIN SKIN: Can't Adjust EQ
    By djXternal in forum MediaCar
    Last Post: 10-28-2004, 03:48 PM
  3. Lilliput problem - Gain settings seem to reset
    By Cheater2k in forum LCD/Display
    Last Post: 09-29-2004, 06:26 PM
  4. Xenarc or Gain are there in-dash options?
    By slushieken in forum LCD/Display
    Last Post: 08-16-2004, 12:12 PM
